Latest: ecthemc
Overall: 3567
Visitors: 148
Total: 148
03: Event Calendar
45: Pictures
51: Pictures
64: Pictures
74: Event Calendar
92: Pictures
102: Event Calendar
104: Pictures
116: Event Calendar
120: Event Calendar
138: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Fuel tanks: poly or alum?
tigerextra
tigerextra
Post Post subject: Fuel tanks: poly or alum?
Posted: Mon Jan 22, 2007 03:55 AM
so i need some opinions, why do the more expensive aluminum tank not poly tank? pros,cons? and also if most driving is to be done on rocky (flagstaff) terrain, tank in front or rear? THANKS FOR ALL YOUR HELP!!! glad to be a member of azbaja!
Post Post subject: Re: Fuel tanks: poly or alum?
Posted: Mon Jan 22, 2007 05:22 AM
I plan on useing two aluminum ones. One in front and one in back, with a universal fuel selecter switch.
I think that plastic would crack too easily.
Crash
Crash
Posted: Mon Jan 22, 2007 06:20 AM
I won't use plastic any more. I couldn't keep it from rotating in the mounts and if left sitting with fuel in the tank it would sag down around the mounting rings.
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Posted: Mon Jan 22, 2007 08:20 AM
If you drive in the snow, put them up front...You always want to be able to turn your car.
Posted: Mon Jan 22, 2007 02:17 PM
Ditto on the aluminum tank. I had a poly fuel cell in my drag car, and after about 7 years it did develop a crack. Not to mention the static electicity problem. If you do use a poly tnak and it has a metal ring around the filler neck, make sure you run a ground wire to it.
Wiggins
Wiggins
Posted: Tue Jan 23, 2007 01:48 AM
We sell them both, our customers are happiest with the aluminum.
General Manager
www.chirco.com
www.chircoestore.com
tigerextra
tigerextra
Posted: Fri Jan 26, 2007 08:25 AM
thanks for the help guys Smile
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1613 rack & pinion w/stock ...
 Wed Nov 09, 2011 06:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3248 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Poly Seats 0 chickenpants 1510 Poly Seats
 Thu Dec 09, 2010 03:09 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Local source for poly seats 4 chickenpants 2021 Re: Local source for p...
 Wed Sep 29, 2010 02:15 PM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 1658 Re: Fuel pump failure
 Mon Nov 02, 2009 06:57 PM
