Visitors: 126
Total: 126
05: Pictures
20: Pictures
24: Event Calendar
33: Garage
82: Event Calendar
95: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- price check 2.3
price check 2.3
azhunter
azhunter
Post Post subject: Re: price check 2.3
Posted: Thu Jan 25, 2007 03:06 AM
Ok, heres some pics of my christmas present from my wife.....
ought to be fun. I need to get ahold of Daryll anyways. Just can't seem to find time when he's at his shop.
Posted: Thu Jan 25, 2007 03:27 AM
what are you going to do about exhaust ?
azhunter
azhunter
Posted: Thu Jan 25, 2007 03:31 AM
Am thinking of an open header or a short bullet till I get a turbo set up.
www.esslingerracing.com has an affordable setup as well as hi po parts.
Posted: Thu Jan 25, 2007 03:42 AM
thanks dude...
Posted: Thu Jan 25, 2007 03:45 PM
1FASTHOE wrote:
thanks for reminding me about time slipping away... So Sad i have myself almost convinced about going watercooled. just thinking about saving some money sounds good to me...
Sorry, didn't mean to rub it in...just typing what I was thinking Rolling Eyes
On the bright side, you are a whole lot closer to playing than I am Laughing
madman74
madman74
Posted: Thu Feb 01, 2007 05:59 AM
If your not going to turbo that egine and want some more power, I can do a little had work to it. For a pocket port and some unshrouding on a stock head I charge $175, Full porting and flow benching is extra. If no turbo you should take the head down and have it milled, 9.5 to 10-1 works pretty well. Wth milling portwork and header that will gve you around 110-115hp, which is a pretty good improvement over the factory rated 88 I can alo get you hydrolic cam grinds that will work with good factory springs that will up that another 10 or so hp. If you want more you can look for an a237 (ford motorsports roller cam, made by crane) this wil give a lopey idle but will need stiffer springs it moves the power band up about 1000 rpm everywhere but at this point you will need to open up the intake some and probably need biger injectors. Or you can just convert it to a turbo motor and be done with it,even t 10 psi you wil be looking at 160-175hp with open exhaust.
Oops it broke!
No new posts VW Volkswagen & Baja Bug General Discussion CHECK YOUR PIVOT BOLTS!!! 2 BugZyla.com 2491 CHECK YOUR PIVOT BOLTS...
 Thu Sep 09, 2010 10:38 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Where to get parts at a decent price 4 Warlock1 1593 Re: Where to get parts...
 Sat Nov 01, 2008 03:04 AM
Thuff View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Check your CV bolts...ask me why. 14 ditch68 5090 Re: Check your CV bolt...
 Sat May 03, 2008 01:15 AM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cardomain.com, check it out 2 joxracing 1274 Re: Cardomain.com, che...
 Mon Mar 03, 2008 12:56 AM
ditch68 View latest post
No new posts Projects and Builds My baja video, check it out! 0 joxracing 1413 My baja video, check i...
 Mon Feb 18, 2008 11:46 PM
joxracing View latest post
