Visitors: 131
Total: 131
26: Event Calendar
51: Event Calendar
64: Event Calendar
80: Event Calendar
81: Event Calendar
104: Pictures
107: Pictures
118: Pictures
129: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- price check 2.3
price check 2.3
madman74
madman74
Post Post subject: Re: price check 2.3
Posted: Wed Nov 15, 2006 10:56 PM
DONT run a supertrap!! it will kill the power! If you are going to run a muffler it should be a straight through one (say no to flowmaster!). Turboengines dont respond the same way that a N/A engine does to exhaust. Anything after the turbo needs to be as big and unabstructed as possible, otherwise there will be more turbo lag and down on hp. A ported manifold will also improve throttl responce will allow the boost to come in sooner, and can make same hp on lower boost. As for wiing for the factory BCS (boost control solinoid) its not worth it, ITs easier just to turn the gillis valve down. this will allow the boost to be turned down to 10psi and up to whatever, the BCS allows 11psi and 15 thats it, you really wont see any real hp until you have a 3" exhaust and atleast 18psi. Trust me this makes a huge difference everywhere.
Oops it broke!
VWDavo
VWDavo
Posted: Wed Nov 15, 2006 11:21 PM
You guys are really getting me jazzed up about running a 2.3. Is it possible to get it set up for less money then a turbo Aircooled VW?
does the Oil pan hang below the Trans too far?
does anyone got some good pics of a setup?
Does anyone know the distance from the back of the engine to the end of the harmonic balancer? (I would like to know if it will stick out of a Thing)
Thanks for any info!
Later
david
-Gerald Ford
saltyslug
saltyslug
Posted: Sun Dec 17, 2006 03:17 AM
I got the wiring up and going and the motor started without the car wiring except the starter. The wiring is so simple, it is still using the factory ECU.
The pinto flywheel and the 2.3 flywheel use a different bolt pattern. We have to get a flywheel that fits the 2.3 cause the pinto pattern is smaller.
The adapter seems to fit right up but I did have to drill it out to work with the 5/8 in alignment studs. The bolt holes seem pretty strait foward. I will be buying a few new bolts for it.
The car also had some wheel locks that I had to get off for the old owner.
I have never had to take wheel locks off with out the key. I just welded some cheapie sockets onto the wheel locks and the heat made them come off with a 3/8 rachet with extension. Dont forget to wear gloves Twisted Evil
DRoZ
DRoZ
Posted: Tue Jan 23, 2007 09:00 AM
Here is the write up on my swap
http://vwbaja.net/drozturboinstall/drozturboinstall.htm
++ When in doubt, please roll me back over!!++
70 VW Baja slightly modified
Intercooled 2.3 EFI Turbo
Posted: Wed Jan 24, 2007 01:22 AM
i cant beleive im going to say this but, im considering looking for a FORD engine for my rail Evil or Very Mad i recently had a engine builder screw me on the delivery of my vdub motor. i've been looking for a 22r but have'nt had much luck. sooooo, maybe i'll go to the dark side and start looking...now, whats the best n/a engine to buy and what year and car does it come in ? madman, how much would you charge to do a swap ? droz, thanks for the link...thanks alot
azhunter
azhunter
Posted: Wed Jan 24, 2007 06:04 AM
I picked mine up on craigslist for $100. Tore the tins off and It's brand spankin new inside. The seller said it had less than 10k on it and now I believe him. Also threw in the engine stand, ecu, harness, fan and some other stuff. There really are good deals out there.
azhunter
azhunter
Posted: Wed Jan 24, 2007 06:08 AM
Posted: Wed Jan 24, 2007 06:50 PM
azhunter, do have any pics up ?
Posted: Wed Jan 24, 2007 09:36 PM
Ohh noo, not another convert.... Who was it that did that non-delivery of your motor, so we can avoid them.
Sorry to hear about a bad experience. Sad
Posted: Wed Jan 24, 2007 09:58 PM
SERRANO'S No! No! No! No!!!! would not answer any of my questions after the purchase(email) he told me 4weeks, i showed him the link on thesamba about him and he assured me it would be 4weeks. well 8 weeks later and still not answering my email, (get ready) my wife lost it and called him, he said he would look into it. he never came back to the phone, she got the charges put back on the card from some lady that worked there... Evil or Very Mad mama was pissed... it wouldn't of been so back if he would just respond back. so if you ever decide to get a engine built by him, dont believe his time line...stinkin liar..
Posted: Thu Jan 25, 2007 12:29 AM
Unfortunatly for him, this is not the first time I heard bad stuff about their follow up. It is a shame you guys had to get wound up Sad Before going to the dark side, have you talked to Fish about an engine? You were looking for a 2 litre weren't you?.....and you mised 1/2 the dune season since you sold your 1600 already huh? No! No! No! No!!!!
Posted: Thu Jan 25, 2007 02:52 AM
thanks for reminding me about time slipping away... So Sad i have myself almost convinced about going watercooled. just thinking about saving some money sounds good to me...
azhunter
azhunter
Posted: Thu Jan 25, 2007 03:09 AM
No pics yet. It's not installed. Still looking for a decent affordable trans and adapter kit. Mean whils, I'm re wiring the harness and stuff. Will post pics of the engine soon though.
Posted: Thu Jan 25, 2007 03:19 AM
how much are you looking to spend on a tranny ? 002 correct ? did you ask daryll ?
azhunter
azhunter
Posted: Thu Jan 25, 2007 03:29 AM
I do have a basketcase 1600 I'd sell reasonably. Ready to assemble. Never ran. Wait a minute,,,we have calssifieds here now! Wheres my camera?
No new posts VW Volkswagen & Baja Bug General Discussion CHECK YOUR PIVOT BOLTS!!! 2 BugZyla.com 2552 CHECK YOUR PIVOT BOLTS...
 Thu Sep 09, 2010 10:38 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Where to get parts at a decent price 4 Warlock1 1646 Re: Where to get parts...
 Sat Nov 01, 2008 03:04 AM
Thuff View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Check your CV bolts...ask me why. 14 ditch68 5292 Re: Check your CV bolt...
 Sat May 03, 2008 01:15 AM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cardomain.com, check it out 2 joxracing 1346 Re: Cardomain.com, che...
 Mon Mar 03, 2008 01:56 AM
ditch68 View latest post
No new posts Projects and Builds My baja video, check it out! 0 joxracing 1482 My baja video, check i...
 Tue Feb 19, 2008 12:46 AM
joxracing View latest post
