Latest: xbluegto
Overall: 3573
Visitors: 128
Total: 128
16: Event Calendar
22: Event Calendar
77: Pictures
84: Event Calendar
116: Event Calendar
125: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Fuel tanks: poly or alum?
tigerextra
tigerextra
Post Post subject: Fuel tanks: poly or alum?
Posted: Mon Jan 22, 2007 04:55 AM
so i need some opinions, why do the more expensive aluminum tank not poly tank? pros,cons? and also if most driving is to be done on rocky (flagstaff) terrain, tank in front or rear? THANKS FOR ALL YOUR HELP!!! glad to be a member of azbaja!
Post Post subject: Re: Fuel tanks: poly or alum?
Posted: Mon Jan 22, 2007 06:22 AM
I plan on useing two aluminum ones. One in front and one in back, with a universal fuel selecter switch.
I think that plastic would crack too easily.
Crash
Crash
Posted: Mon Jan 22, 2007 07:20 AM
I won't use plastic any more. I couldn't keep it from rotating in the mounts and if left sitting with fuel in the tank it would sag down around the mounting rings.
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Posted: Mon Jan 22, 2007 09:20 AM
If you drive in the snow, put them up front...You always want to be able to turn your car.
Posted: Mon Jan 22, 2007 03:17 PM
Ditto on the aluminum tank. I had a poly fuel cell in my drag car, and after about 7 years it did develop a crack. Not to mention the static electicity problem. If you do use a poly tnak and it has a metal ring around the filler neck, make sure you run a ground wire to it.
Wiggins
Wiggins
Posted: Tue Jan 23, 2007 02:48 AM
We sell them both, our customers are happiest with the aluminum.
General Manager
www.chirco.com
www.chircoestore.com
tigerextra
tigerextra
Posted: Fri Jan 26, 2007 09:25 AM
thanks for the help guys Smile
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1721 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3424 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Poly Seats 0 chickenpants 1618 Poly Seats
 Thu Dec 09, 2010 04:09 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Local source for poly seats 4 chickenpants 2179 Re: Local source for p...
 Wed Sep 29, 2010 02:15 PM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 1770 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
