Latest: BlackIrish05009
Overall: 3574
Visitors: 124
Total: 124
03: Event Calendar
05: Event Calendar
09: My Account
12: My Account
20: Pictures
40: Event Calendar
44: Event Calendar
59: Event Calendar
63: Event Calendar
115: Event Calendar
124: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Which wire is which - to the coil?
SandRacer
SandRacer
Post Post subject: Which wire is which - to the coil?
Posted: Mon Jan 08, 2007 07:41 PM
When I took everything apart to install my new carbs and distributor, I carefully marked and labeled the wiring. Everything went back together just fine except for the wires to the coil. Seems the tape dried out and fell off. So, I thought I had a 50/50 shot and connected the wiring to the coil. It just would not start up.
I'm hoping that I didn't short out the Comp-u-Fire Electronic Ignition.
How can I determine which wires from the harness go to positive and negative on the coil?
I have a spare coil and another dizzy with a Pertronix unit in it but I'd like to get the wiring straightened out before I run the risk of ruining more parts.
1976 Baja Bug
Post Post subject: Re: Which wire is which - to the coil?
Posted: Tue Jan 09, 2007 12:29 AM
The hot wire aka the one that comes on when you turn the key on goes to the plus side of the coil. the neg will run to the points and the points is ground.
SandRacer
SandRacer
Posted: Tue Jan 09, 2007 04:17 AM
Thanks. I'll throw a test light on 'em.
1976 Baja Bug
bajasam96
bajasam96
Posted: Tue Jan 09, 2007 06:06 AM
Those compufire units are very easy to destroy, IE: connecting posi-to-neg and neg-to-posi... hold your breath...
On a slightly more abstract note, you technically can run your coil backwards, though your engine will only run 40-60 percent of its regular capacity. So its not likely to start wired backwards. Most people wont believe ya when you say that, but its true.
Posted: Tue Jan 09, 2007 08:59 AM
Also make sure you hava a ballest or resitor wire if you coil is not a inter ballest coil.
SandRacer
SandRacer
Posted: Tue Jan 09, 2007 06:13 PM
OK. How can I tell which type I have?
1976 Baja Bug
Posted: Tue Jan 09, 2007 06:34 PM
you need an ohm meter.
www.ratwell.com/techni...eCoil.html
www.hot-spark.com/Inst...butors.htm
72.14.253.104/search?q...=clnk&cd=8
SandRacer
SandRacer
Posted: Tue Jan 09, 2007 06:57 PM
Thanks for the help. I do have a meter so I'll check the coil(s). From what I read on the links it looks like I may have fried the compufire. I'll get the right coil wired up properly and see if she'll start. If she doesn't, I suppose I could put the Pertronix unit back in and try again.
1976 Baja Bug
SandRacer
SandRacer
Posted: Wed Jan 10, 2007 06:00 AM
The original coil showed 3.5 ohms and the blue coil showed 3.8 so I just left the blue on one. I got the wires on properly, now, but it looks like I probably smoked the compufire. She still won't start.
I emailed Compufire to see if I can test the unit to make sure before I order another one.
I'm hoping the wife can give me a hand tomorrow, to turn the key, so I can check for spark and go from there. I have a remote starter switch but it's very old and tired and not very reliable. Sad Could be too many years of use by my kids when they would get too lazy to change out an ignition switch.
Wait a minute. That sounds like a legitimate reason to buy a new tool!!! Very Happy
1976 Baja Bug
Posted: Wed Jan 10, 2007 04:28 PM
Hey that sounds like me!! Very Happy Very Happy
SandRacer
SandRacer
Posted: Thu Jan 11, 2007 03:49 AM
I got a reply from Comp-U-Fire about testing their unit.
Use a 12 volt testlight on the negative side of the coil crank the engine and the light should flash bright dim. If it does not then you probably fried the module.
I thought I'd share their response in case someone else may need to use it. I'm not sure if this same method would work to test other "points eliminators" like a Pertronix.
1976 Baja Bug
bigsam
bigsam
Posted: Sat Jan 13, 2007 03:45 PM
yes it wood. its basikly a on off switch for your coil. also you shood have a wire from your starter switch too your coil with out a rezister for the extra power on startup. good luck
DRIVEIT LIKE YOU
STOLE IT
Posted: Fri Feb 29, 2008 08:29 AM
Bump
No new posts VW Volkswagen & Baja Bug General Discussion Does any one have any coil over springs for 2.5 shocks?
16 Ejbbal21 7936 Does any one have any ...
 Sat Oct 06, 2012 10:05 PM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion COIL VOLTAGE 3 cheapbeetle 1974 Re: COIL VOLTAGE
 Sat Sep 06, 2008 04:38 PM
cheapbeetle View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wire harness 6 locutisj 2002 Re: Wire harness
 Mon May 26, 2008 07:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Is the coil over conversion kit worth it?
17 zx10r203 25650 Re: Is the coil over c...
 Sat Apr 19, 2008 05:46 PM
hoserbug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Where to find used coil overs 4 Geargrinder65 1844 Re: Where to find used...
 Thu Sep 13, 2007 08:30 AM
atattoojay View latest post
