Latest: Smokey4
Overall: 3593
Visitors: 91
Total: 91
12: Home
30: Pictures
50: Event Calendar
81: Home
Baja Forums -:- AzBaja.com Members -:- New Members -:- Scott and his 73 Super Beetle
scotter
scotter
Post Post subject: Scott and his 73 Super Beetle
Posted: Fri Jan 05, 2007 01:55 AM
Hey all,
First off thanks to all who host and give thier two cents on this site. For me, this being my first vw, it has been a life saver. I have build older trucks and cars before, but a bug is almost like a parralel universe. Same but different. I am planning on getting everything running first then figuring my next step. Pretty much all orginal with ac, ira, and a duel port, so I have somthing to start with, yet the car has set out in the sun for over 3 years.... I will update as I go and if anyone has thoughts, feel free to post, I would appreciate any help.
Thanks again,
Scotter
Crome wheels makes anything go faster!!
Billy
Billy
Post Post subject: Re: Scott and his 73 Super Beetle
Posted: Fri Jan 05, 2007 06:36 AM
welcome! I myself am building a 74 standard. Post pics! Even though its a stocky Wink
scotter
scotter
Posted: Fri Jan 05, 2007 05:53 PM
UPDATE:
The bug now breaths life!! and a little fire, note to self: be more carelful with chemicals around the engine. I have rebuilt the carb, put on all new rubber tubing for the gas lines, cleaned all the metal gas lines, put in a new gas tank, new starter, new plug wires, new cap and rotor and points, flushed the motor, new rubber on the Brake lines and cleaned the metal tubing. Cleaned the wheels up and baught some new rubber for them
Now I need to install a new master cylinder, bleed the brakes, and a couple more loose ends and I should be good.
Thanks again for the site,
Scotter
Posted: Sat Jan 06, 2007 09:05 AM
glad to see ya on board!
did ya install a new fuel filter to compliment the new fuel line??
make sure you bench bleed that massa cyl before installin it.
please post some pics Very Happy
Billy
Billy
Posted: Sat Jan 06, 2007 09:39 AM
whats bench bleed and how do you do it cuz i just treated my baja toa new master..?
Posted: Sat Jan 06, 2007 10:06 AM
find a bench (of some sort). remove the resevior cap from the massa cyl. add some brake fluid. now use a long shank screw driver and push the massa valve in a few times to get the air to bleed out. just dont make a mess Wink
I was told there is a way to install a new massa and not have to bleed the whole system down. of course its privilidged info that Im not allowed yet ...... Rolling Eyes
Billy
Billy
Posted: Sat Jan 06, 2007 08:35 PM
i might have to bleed the entire system anyway as most of my brake lines are going to be replaced
6Rage
6Rage
Posted: Sat Jan 06, 2007 10:10 PM
when you redo your brake line check for cholesterol in the rubber lines, if there is any u HAVE TO clean out your steal lines. i didnt do that and when i would hit the brakes she would pull hard to the left. thought u should know.
My other cars a UDLX
Need to know the method to my madness? email me I'll tell ya bajarage @ hotmail.com.
Billy
Billy
Posted: Sat Jan 06, 2007 11:53 PM
sure it wasnt that yur brake pads werent adjusted off from eachotheR? Mine pulls to the right sometimes at a slow speed so every few weeks I have to go and adjust em evenly again
scotter
scotter
Posted: Sun Jan 07, 2007 03:31 AM
yep she got a new fuel filter and one to go in the glove box just in case, gonna try to do the master cylinder tonight and take her on her maiden voyage!!
Posted: Sun Jan 07, 2007 05:48 AM
Cool
1 suburbangorilla 3731 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion big beetle 3 bugzapper 2635 big beetle
 Wed Dec 17, 2014 06:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2258 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts Projects and Builds my 72 super project 2 vtbaja 2925 my 72 super project
 Tue Jan 21, 2014 11:34 PM
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4558 super baja question
 Thu Aug 29, 2013 11:07 PM
