Visitors: 108
Total: 108
26: Event Calendar
38: Links
60: My Account
79: My Account
81: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How important are shock limit straps. Do I really need them?
Billy
Billy
Post Post subject: How important are shock limit straps. Do I really need them?
Posted: Thu Jan 04, 2007 04:27 AM
I dont quite understand their purpose. SOmeone explained it to me once, but again, how do I determine what size I need? Thanks
VIN70
VIN70
Post Post subject: Re: How important are shock limit straps. Do I really need t
Posted: Thu Jan 04, 2007 05:03 AM
they limit the suspension from fully extending past the shocks limit to avoid damaging the shocks usually 1" from the shocks limit
azhunter
azhunter
Posted: Thu Jan 04, 2007 05:07 AM
They are a good idea. you either need bump stops or straps. This prevents damage to your shocks and suspension components i.e. ball joints/tie rod ends. when the suspension gets air born it will attempt to pull the valve off of the piston shaft cousing it to break or not work. This can also snap a ball joint in two. To my knowledge, you measure full travel in unloaded state and subtract 1 1/2 to 2 in. to allow for stretch.
azhunter
azhunter
Posted: Thu Jan 04, 2007 05:08 AM
Billy
Billy
Posted: Thu Jan 04, 2007 05:27 AM
But since I will not be catching serious air, or at least hangtime anyway, should I highly cconsider them? Are they an easy mount?
Posted: Thu Jan 04, 2007 06:00 AM
use em if ya got em....kinda like a rubber. always safe! Wink
Wiggins
Wiggins
Posted: Thu Jan 04, 2007 03:31 PM
Billy
What suspension are you running?
General Manager
www.chirco.com
www.chircoestore.com
Wiggins
Wiggins
Posted: Thu Jan 04, 2007 03:36 PM
Messure your extended travel eyelet to eyelet of where your shockbolts are and subtract 1/2" to an 1"
General Manager
www.chirco.com
Billy
Billy
Posted: Fri Jan 05, 2007 05:07 AM
Wiggins
Im just running a stock balljoint (its a 74)
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 2574 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
No new posts Events and Get Togethers World Wide IMPORTANT: Hassayampa Followup
20 wideopenmotorsports 11167 IMPORTANT: Hassayampa ...
 Sun Mar 16, 2014 10:32 AM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Hoops
Wanting to build shock mounts without cutting the body
29 POCman 24331 Re: Shock Hoops
 Thu Nov 15, 2012 07:50 AM
POCman View latest post
15 onthefarm 10983 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
No new posts VW Volkswagen & Baja Bug General Discussion shock setup 5 thext94 4614 Re: shock setup
 Wed Apr 14, 2010 02:16 PM
