Latest: DunnsBug
Overall: 3604
Visitors: 158
Total: 158
05: My Account
27: Event Calendar
51: Event Calendar
58: Event Calendar
70: Garage
72: Event Calendar
74: Event Calendar
77: Home
84: Event Calendar
85: Event Calendar
99: Event Calendar
104: Event Calendar
106: Event Calendar
110: Home
113: Event Calendar
138: Pictures
148: Event Calendar
150: Event Calendar
154: Event Calendar
157: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- ball joint front end on a baja?
camrenmarley
camrenmarley
Post Post subject: ball joint front end on a baja?
Posted: Tue Jan 02, 2007 03:04 AM
everyone i talk to tells me that i cant have a ball joint front end if i want to build a baja bug. is this true? is there a king link pin conversion kit?
jmallen
jmallen
Post Post subject: Re: ball joint front end on a baja?
Posted: Tue Jan 02, 2007 04:12 AM
I have a balljoint front on mine and haven't had any problems. There weaker than link pin, it just depends how serious your going to get. I'm no expert, just my 2 cents.
madman74
madman74
Posted: Tue Jan 02, 2007 06:54 AM
I think a stock balljont front end is stronger than a stock link pin. The problem is either pulling out the balljoints or breaking them. I justtacked the ball joints in on mine. As for breaking them I think this is mostly cause by raisoing the front end too high, or not having any kind of limiters on it and using the ball joints as bump stops. Ball joints dont have lot of travel but either does a stock link pin. Another problem with ball joint front ends are (A personal problem) THEY ARE UGLY. I saykeep the ball joint if you arent doing anything crazy and dont need ons of travel.
Oops it broke!
Posted: Tue Jan 02, 2007 04:07 PM
I run a 6 inch wider balljoint beam in my baja, and a stocker in my rail. No problems, you just have to know their limits. for mild to moderate offroading they work fine. Lime madman74 said theough, you are limited to travel on a balljoint, but with a few mods and longet shocks, or coil overs, you can get a ton of travel out of a linkpin.
Posted: Tue Jan 02, 2007 07:00 PM
Old worn-out parts = breakage. Keep it tight and you'll be fine.
5 Admin_AzBaja 9744 Baja Bugs on Wiki need...
1569 mufasavnvmc 1120709 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 270581 Re: Baja sightings
103 SuburbanLegend 153752 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 2301 FREE VW BAJA'S
