Visitors: 107
Total: 107
32: Home
44: Event Calendar
76: Home
89: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- ball joint front end on a baja?
camrenmarley
camrenmarley
Post Post subject: ball joint front end on a baja?
Posted: Tue Jan 02, 2007 03:04 AM
everyone i talk to tells me that i cant have a ball joint front end if i want to build a baja bug. is this true? is there a king link pin conversion kit?
jmallen
jmallen
Post Post subject: Re: ball joint front end on a baja?
Posted: Tue Jan 02, 2007 04:12 AM
I have a balljoint front on mine and haven't had any problems. There weaker than link pin, it just depends how serious your going to get. I'm no expert, just my 2 cents.
madman74
madman74
Posted: Tue Jan 02, 2007 06:54 AM
I think a stock balljont front end is stronger than a stock link pin. The problem is either pulling out the balljoints or breaking them. I justtacked the ball joints in on mine. As for breaking them I think this is mostly cause by raisoing the front end too high, or not having any kind of limiters on it and using the ball joints as bump stops. Ball joints dont have lot of travel but either does a stock link pin. Another problem with ball joint front ends are (A personal problem) THEY ARE UGLY. I saykeep the ball joint if you arent doing anything crazy and dont need ons of travel.
Oops it broke!
Posted: Tue Jan 02, 2007 04:07 PM
I run a 6 inch wider balljoint beam in my baja, and a stocker in my rail. No problems, you just have to know their limits. for mild to moderate offroading they work fine. Lime madman74 said theough, you are limited to travel on a balljoint, but with a few mods and longet shocks, or coil overs, you can get a ton of travel out of a linkpin.
Posted: Tue Jan 02, 2007 07:00 PM
Old worn-out parts = breakage. Keep it tight and you'll be fine.
5 Admin_AzBaja 6749 Baja Bugs on Wiki need...
1568 mufasavnvmc 998166 Re: what did you do to...
285 MusicManiac 241006 Re: Baja sightings
0 Northmountainauto 1511 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4085 Baja hiding in Chandle...
