Latest: George
Overall: 3576
Visitors: 133
Total: 133
05: My Account
15: Event Calendar
35: My Account
72: Event Calendar
98: Home
117: Event Calendar
127: Event Calendar
131: Event Calendar
1963BAJA
1963BAJA
Posted: Wed Jun 21, 2017 07:14 PM
It sat like this for about 7 or 8 months while i had other stuff going on. Worked on a little side project for my friend. Amazingly got a T3 turbo and massive holley carb installed and running and fit under the hood of his 72 street bug. Only took us about 3 days to do most of the work then another week to finish it up and get it running right.
Azdrtdog
Azdrtdog
Posted: Wed Jun 21, 2017 07:45 PM
lookin good, be gentle to the 3 rib and you can dial the car in while you look for a stronger trans. NOW what's this about Honda motors that turn the wrong way??? Because I just found the perfect engine for the suby trans I was getting ready to flip the carrier in. Yes I want details
1963BAJA
1963BAJA
Post Post subject: Re: The Socal Honda Build
Posted: Wed Jun 21, 2017 08:04 PM
The older b and d series Honda motors were counter clockwise rotating engines and I believe I read the reason for this was because they were originally designed as right hand drive cars and something about the transmission playing a factor in why they designed them to rotate counter clockwise but that was a while ago. I know there's a company that sell the parts to reverse the rotation of a subie trans without compromising strength I think I saw they were located in Australia? It's been a couple years since I looked into any of that stuff.
Azdrtdog
Azdrtdog
Posted: Wed Jun 21, 2017 08:11 PM
Ya subarugears sells r&p along with a few other needed parts for $1900 so that's my next project, I looked up the series motors and they are all 4 bangers
Unfortunately. Oh well I'm happy with the boxer setup for now, thanks though
1963BAJA
1963BAJA
Posted: Wed Jun 21, 2017 08:26 PM
The b and d series are great motors. I believe the f and h series Hondas also rotate counter clockwise. And there was another v6 that Honda used in the early 90s but I am unsure of its rotation. But parts availability would be slim I would imagine on that one. The b d and f are really popular to build and turbo or sometimes supercharge and guys will sleeve the blocks and depending on the budget and type of fuel your using can make anywhere from 300 and I've heard rumor of up to as much as 600 to 700 out of a little 4 banger running e85.
Actually a friend of mine has a mid 90s hatch back that he's turbod and getting ready for e85 and the guy he had build the block claims it's safe to run up to 800 hp. Personally I feel like that's a little excessive but it's his drag car so I guess it's necessary.
Azdrtdog
Azdrtdog
Posted: Wed Jun 21, 2017 08:40 PM
Oh I know they make stupid hp out of those things, I'm looking for big fat silky torque. I want a 1000-1500 rpm grunt for them rocky bumpy spots that a v6 puts down
1963BAJA
1963BAJA
Posted: Wed Jun 21, 2017 08:52 PM
That's one reason I went towards the j series but mainly it's because there so cheap. If this one ever goes I can replace it for under 800 bucks. And if I leave the motor stock it'll be plenty reliable for me and easy to replace if I ever have to.
Posted: Thu Jun 22, 2017 12:04 AM
A 002 nor a 091 wont hold up to a V6 .... been there.. broke that.
an .091 is only good up to 200hp built smart. The 002 and the 091 will hold for a while on the street but when you go off roading they break. It is the torque that kills them.
got a Mindy 5 sp... never looked back... good up to 350hp.
You have a lot of work into the car, looks good.. I am looking for a fight. I am just surprised I the first one to break you the news.
1963BAJA
1963BAJA
Posted: Thu Jun 22, 2017 12:16 AM
Yea I have my fears about cracking the case on the 002 but I only paid 100 bucks for it so I figure it's worth a shot anyways and of it goes I won't be too upset about it
My dad has a 091 that was put together by mendeola back in the day but he won't separate with it otherwise I would be using that. I do plan on leaving the engine stock for reliability on both the engine and transmission but I also don't expect the trans to last forever.
I still have a bunch more pictures to post to get this thread caught up to where I am today. Currently I've got 90% of the cage work finished just need to do some reinforcing on it in some areas that I'm worried about. But currently it's sitting on all 4 tires with disc brakes all around. The spindles look to be some old tweed combo spindles but not sure on who exactly made them. They are definitely combo spindles.
I still have to mount the radiator in the car. Get a fuel pump and configure all of that. Fabricate some sort of fan shroud set up so I can get air flowing the way I need it to. I've been working on getting the wiring started for the car then I have to redo my engine wiring because when I first wired it I planned on using the stock computer but I now have a megasquirt for it. I'll have to get axles for it at some point.
My main reason I'm posting my build thread on here though as opposed to the samba or other sites is because I actually plan on moving to the Prescott area in August and it would be nice to find out where I can take this thing once I get it running finally.
Azdrtdog
Azdrtdog
Posted: Thu Jun 22, 2017 12:41 AM
Case should be fine, pinion on the other hand
Posted: Thu Jun 22, 2017 01:25 AM
In my rail my stock Nissan 3.0 with my 2 091,s one was always getting fixed. 4 - 5 ring and pinions, a few spider gears, 2 maybe 3 first gears. then I twisted the case... I was done.
You got a lot of work there... to cut it all out to put in a Mendeola.
1963BAJA
1963BAJA
Posted: Fri Jun 23, 2017 12:15 AM
I am worried about having to redo my transmission set up but i got it for so cheap im not that attached to it when it does go south.
I suppose i should get this caught up to where i am today. its been a slow build but over time i got little things done here and there.
i took my sweet time getting my shock hoops built and shocks mounted. but i did finally get them all situated where they needed to be
i dont have a ton of pictures of the little things i did here and there along the way but i have some pictures of how it currently sits
my current goal is to get some wiring started for this thing at least while im waiting for my radiator to show up its been on backorder..
the only things i can think of that arent in these pictures that ive done since are the front shock hoops have been braced, i got a front disc brake setup, got my battery box mounted, started a fuse/relay panel, and my tail light mounting set up is one of a kind.. Cool
Cheapskate special
26 Azdrtdog 9355 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts New Members New to the forum. Hailing from Socal currently.. 1 1963BAJA 1588 New to the forum. Hail...
 Sun Oct 23, 2016 06:59 AM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 4513 New Class 11 Build - P...
101 SuburbanLegend 124979 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
61 1450bug 48809 1450Bug Build
 Fri Jan 23, 2015 03:41 AM
