Latest: rcwtony
Overall: 3607
Visitors: 168
Total: 168
04: Pictures
45: Home
50: Event Calendar
58: Event Calendar
75: Pictures
77: Event Calendar
99: Event Calendar
109: Event Calendar
120: Event Calendar
134: Event Calendar
136: Contact Admin
146: Event Calendar
150: Baja Forums
154: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Go Full Coilover With Through Rods or Just Use Stiffer Leafs
Trevabooooy
Trevabooooy
Post Post subject: Go Full Coilover With Through Rods or Just Use Stiffer Leafs
Posted: Thu Jun 01, 2017 10:23 PM
Hey guys, this has probably been answered time and time again but whats the point of a forum on VWs if you don't answer questions that have already been answered hundreds of times?
Anyways, Im building my 68 and am going to convert the front back to a Link Pin Beam. I recently picked up a JD2 Model 32 Hydraulic so ill build my own Beam, and Pan Head from 2" .120 wall DOM so I can push the beam forward a little bit. Im going to go 6" wider than stock and have an old Link Pin Beam that I can use as a guide. Ill be doing longer swing arms too. My question is, am I better off ditching the Leaf Pack and going full Coilover? Or should I go with 6" wider and stiffer Leaf Packs with a Reservoir Shock? Or a combination of both? Im not concerned with staying SCORE compliant as I won't race this thing, its purely for my own enjoyment. Ill jump it, bomb fire roads, and drive it on the street so it needs to be strong, reliable, and street savvy.
Speaking of longer Trailing Arms, who makes good ones? Preferably not cast.
Thanks.
Signatures are stupid
Posted: Fri Jun 02, 2017 12:40 AM
Full coil over is going to cost more
Post Post subject: Re: Go Full Coilover With Through Rods or Just Use Stiffer Leafs
Posted: Fri Jun 02, 2017 02:18 PM
Thanks.
go 8" or more on the front beam... I am at 7 3/4" and it still rubs in a sharp turn with a bump. with 3x3 in the back it tracks nicely with the rear wheels. wish I went 10" over.. Stock Leaf Packs break when you off road them. they are only good for stock arms.,. I went with aftermarket leaf packs and I did not have a problem with 1 1/4" over on the arms but it would collapse when I would brake. if you can afford it ... go coilovers ...
spend the few extra bucks and run the 7/8" shafts they hold up better.
No new posts Projects and Builds My 70' Full Fender Baja Project 1 McKenna 4963 My 70' Full Fender Baj...
 Mon Aug 18, 2014 09:57 PM
McKenna View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Full bodied bajas 2 desertbaja 4585 Full bodied bajas
 Sun Aug 19, 2012 05:29 AM
sandfreaks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin stiffer front torsion leafs 6 nvlandshark 5768 Re: Link Pin stiffer f...
 Sat Jan 16, 2010 03:03 PM
nvlandshark View latest post
No new posts VW Volkswagen & Baja Bug General Discussion bent front torson leafs 6 1969Type1BAJA 2689 Re: bent front torson ...
 Mon Nov 16, 2009 06:54 PM
No new posts VW Volkswagen & Baja Bug General Discussion Reinforce your tie rods!!!
19 57baja 20428 Reinforce your tie rod...
 Sat Oct 17, 2009 02:28 AM
57baja View latest post
