Latest: rcwtony
Overall: 3607
Visitors: 231
Total: 231
10: Garage
40: Home
77: Event Calendar
113: My Account
121: Pictures
138: Event Calendar
142: My Account
162: Baja Forums
169: Event Calendar
177: Event Calendar
179: Baja Forums
181: Baja Forums
185: Baja Forums
188: Baja Forums
194: Baja Forums
197: Baja Forums
198: Baja Forums
199: Baja Forums
201: Baja Forums
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: Baja Forums
210: AMAZON.com
211: Baja Forums
212: Pictures
213: AMAZON.com
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
222: Event Calendar
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
My 69 project
1 2 3 ... 76 77 78 79 80
Azdrtdog
Azdrtdog
Posted: Wed May 24, 2017 05:58 PM
Time to put coilovers on dalton
Posted: Fri May 26, 2017 01:53 PM
ordered my 29mm got my standard adjustors. looking at the car.... Dam ... this is going to be a lot of work.
Azdrtdog
Azdrtdog
Posted: Fri May 26, 2017 01:57 PM
Lot more work then coils and you still have to worry about it breaking again
Posted: Tue Jun 06, 2017 01:27 PM
Got the 29mm torsion Friday.... I called and the splined center is on back order... Unknown ship date...
Bummer.
Posted: Tue Jun 13, 2017 02:22 AM
got the motor out... not too bad.. made a few changes to my oil lines... found only 2 bolts loose!!!! WOW!!! I was able to pull the motor with out opening up the AC system ... worked like a charm...
stopped just short of opening up the CV's ... going to start on them Tuesday... did some searching on the internet and found out how to get 32degrees out of them.??.. I will check it out when I go to put them back in.
found out why my throttle cable was sticking... I did not see that coming. but the housing was getting pulled back ... got to get that fixed ..
Azdrtdog
Azdrtdog
Posted: Tue Jun 13, 2017 03:22 AM
will torsion bars like 32 degrees is the next ?
Azdrtdog
Azdrtdog
Posted: Tue Jun 13, 2017 07:51 PM
maybe a nice quarter elliptical spring setup, that would be unique
Posted: Wed Jun 14, 2017 12:08 AM
32 degrees on my 930 CV's
Azdrtdog
Azdrtdog
Posted: Wed Jun 14, 2017 12:14 AM
yes I know, my thoughts were with the torsion bars cycling 24" of travel so you could benefit from cv's that have that much angle
Posted: Wed Jun 14, 2017 01:32 PM
I was told that torsions bars can twist up to 2.5 turns before breaking.
Azdrtdog
Azdrtdog
Posted: Wed Jun 14, 2017 01:44 PM
I totally want to test that claim
Posted: Mon Jun 19, 2017 01:38 PM
UGH.... well I have the trans pulled and every thing out of the way...
Guess what.... I blew the outer splines... All that work.. and I blew a spring plate. I could have been back up and running in a few hours ...
oh well... been doing some small changes here and there.
last night I decided I am going to replace the inner splines anyway ... they are a weak spot ...
I am ordering up some parts today..
Posted: Fri Jun 23, 2017 02:17 PM
Posted: Fri Jun 23, 2017 02:19 PM
I am ready.... where is my replacement splines???
Posted: Fri Jun 23, 2017 02:22 PM
now you can get a better look at the way I did my heater and other lines..
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 5313 Project Purple People ...
88 Dirtjunkie 74976 Project II
65 PaDan 66319 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 10206 Re: new project
38 NoKnowledgeCollegKid 27170 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
