Visitors: 201
Total: 201
07: Event Calendar
08: Event Calendar
11: Pictures
20: Event Calendar
22: Event Calendar
37: Event Calendar
38: Event Calendar
44: Event Calendar
58: Event Calendar
59: Event Calendar
76: Event Calendar
77: Event Calendar
79: Event Calendar
80: Event Calendar
84: Event Calendar
86: Event Calendar
87: Event Calendar
90: Event Calendar
94: Event Calendar
95: Event Calendar
96: Event Calendar
98: Event Calendar
103: Event Calendar
104: Event Calendar
106: Event Calendar
117: Event Calendar
127: Event Calendar
129: Event Calendar
130: Event Calendar
132: Event Calendar
133: Event Calendar
134: Event Calendar
135: Event Calendar
136: Event Calendar
138: Event Calendar
142: Event Calendar
154: Baja Forums
168: Pictures
170: Baja Forums
172: Baja Forums
175: Pictures
176: Baja Forums
177: Baja Forums
178: Baja Forums
179: Event Calendar
180: Event Calendar
181: Event Calendar
182: Event Calendar
183: Event Calendar
184: Event Calendar
185: Event Calendar
186: Event Calendar
189: Baja Forums
195: Baja Forums
197: AMAZON.com
198: Baja Forums
200: Baja Forums
My 69 project
1 2 3 ... 75 76 77 78 79 80
Posted: Thu Feb 16, 2017 02:32 AM
Posted: Sun Mar 05, 2017 09:19 PM
Posted: Sun Mar 05, 2017 09:21 PM
Posted: Sun Mar 05, 2017 09:22 PM
remote Oil system is done..
Posted: Sun Mar 05, 2017 09:23 PM
had to get my own welder.
spring plates are done.
Posted: Sun Mar 05, 2017 09:26 PM
did you know the VW made a longer clutch arm?
works awesome on stage 1 -3 pressure plates...
no more heavy peddle.
RaceJunkie
RaceJunkie
Posted: Tue Mar 21, 2017 04:57 AM
Hot vws posted this to facebook
[/img]
Posted: Wed Mar 22, 2017 02:13 AM
Nice!
Posted: Sat Apr 22, 2017 01:44 AM
baja is back up...
Posted: Sat Apr 22, 2017 01:47 AM
almost ready for the 400miler....
I just need to adjust the rear breaks and take a pre run trip ...
I re-did my camping trailer ... it was much more work than I thought but I am happy with the way it came out.
Azdrtdog
Azdrtdog
Posted: Sat Apr 22, 2017 03:28 PM
And he had time to swing by and give me a hand swapping transaxles in my car,
Posted: Mon May 08, 2017 02:56 PM
For the past 2 years I have been having a weird flat spot issue and a hard start issue. I am using a JDM Subaru 2.5l and spent a few hours Googleing my problems to find out that JDM Subaru motors Throttle position sensor confuses a domestic ECM for some reason??!! I replaced the throttle position sensor, calibrated to my ECM and now the car has more power and runs much better... No more flat spots!! Kenny came by and he helped me understand a few codes and readings, I have a little more work to do... cant see the motor running much better.?! But would like better fuel economy... I only run the stock 10gl tank.
I am still on for " Paint 2017! "
Posted: Wed May 10, 2017 01:42 PM
the Flat spot is gone....!!!! seems to have more power..??! checking to see if I get better mileage. Now I only have hard start for the first start after that I am fine.
AC is working great! she just needs to be loaded up for the 400...
Posted: Wed May 10, 2017 03:34 PM
Congrats Dalton!!
Posted: Wed May 24, 2017 04:03 PM
5/1600 Torsion adjuster install
Here's the link for the install the guys did in their 5/1600 race car. Not exactly a how to but there are some pictures at least
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3409 Project Purple People ...
88 Dirtjunkie 62768 Project II
65 PaDan 57098 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8351 Re: new project
38 NoKnowledgeCollegKid 21788 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
