Visitors: 158
Total: 158
37: Pictures
42: Event Calendar
51: Event Calendar
60: Event Calendar
63: Event Calendar
67: Event Calendar
68: Event Calendar
81: Event Calendar
98: Event Calendar
125: Event Calendar
135: Event Calendar
156: Pictures
157: Event Calendar
1 2 3 ... 103 104 105
ghettodish
ghettodish
Posted: Mon May 05, 2014 06:34 AM
My first attempt at replacing floor pans. Off to a good start...
Posted: Tue May 13, 2014 12:46 PM
Just driving the Car. Have more work to do on it but will wait tell summer and drive it when it is cool.
terribletommy
terribletommy
Posted: Mon Aug 04, 2014 02:19 AM
I had a blast! It rained a little yesterday so I went and found some mudd!
The four b\'s.. beer, babes, buddies, and baja bugs... oh wait thats five.
dave46
dave46
Posted: Fri Sep 11, 2015 08:21 PM
DOH !! Snapped off a stub axle. I'm not sure but I think this was an EMPI shaft. I was not beating on it at the time just driving down the street.
Posted: Thu Oct 08, 2015 08:01 PM
I broke the nut side of on a stub axle on my baja. I have disc brakes so I was able to limp home. Would not of been able to do that with drum brakes.
Marlon1990
Marlon1990
Posted: Mon Jan 11, 2016 03:26 PM
There was NO damage to my car except for the seat cam going out and laying my seat back.
Posted: Wed Jan 27, 2016 04:20 AM
Still fun, True.
Posted: Fri Aug 05, 2016 08:33 PM
Started the rebuild of Project II, Picked up, bumpers, cage and steering box & tie rods last week.
Posted: Thu Jan 05, 2017 10:42 PM
Some small mods: upgraded existing wiper assembly (lock screw arm, lower 2 in pic) to newer style(spline type arms, upper arm in pic) hopefully for better windshield contact pressure, these have bigger hold springs than old style.
Modified existing wiper motor assembly for spline type shafts/arms because I knew what shape it is in plus it's clean/painted, Upper 1 in pic is older style w/lock screw type shafts. Removed spline type shafts (lower assembly in pic) drill holes a little bigger & installed shafts in old style assembly. Note:this was a "before" picture
Added/modified rear (smaller) heat boxes over stinger exhaust system for a little more heat. Starting to get cold here in NC
Posted: Sat Jan 07, 2017 12:20 AM
I look at Baja and went inside.
Posted: Mon Feb 06, 2017 08:04 PM
I made a little progress last night, Battery was still good, started and ran, moved to driveway, still had brakes or some pedal. lol
Fought for several hours trying to get glass put in rear window until I youtubed and found I'm going to need help. So I plan on having the wife help me tomorrow.
I have to do all the rear window seals. I had been holding off on doing them forever because I wanted to paint it first, but to hell with it, it's staying rat.
Have a great day all.
Posted: Wed Feb 08, 2017 06:07 PM
Thanks to Sal at Parts Authority aka Bap on 27th and Camelback for hooking me up with another rear window seal after I destroyed the first. LOL
And thanks to my Wife and friend Tomas for helping me get two windows done. Smile
Passenger side quarter window hopefully tonight, but my fingers are very sore. lol
Interesting note is that the headliner was under the seal on the quarter windows and trimmed from the outside of the car before the windows were originally installed, so my seals and windows are original to the bug.
Edited to change name of store, I always mix it up with advanced pars.
Posted: Sun Feb 12, 2017 08:44 AM
All rear windows are sealed up, doors have new outer seals.
Still runs pretty good or nearly the same and unfortunately pulls hard right under braking. lol There's never nothing to do.
Vacuumed it out and found a lizard living in it and rescued from starvation.
2yr old loves to drive in it. Smile
Baja_Boy
Baja_Boy
Posted: Wed Mar 01, 2017 12:28 AM
Hi AZBAJA I am 16 and about a month ago I bought my first car it is a 1964 baja bug, and I absolutely love it. Today I took all of the trim out of my baja and welded up all of the holes then I put Bondo on the negative body work and I sanded the bondo down.
(please PM me if you have some baja or rail parts that you may want to sell me or give away to me much appreciated)
It's nothing a little welding can't fix
Posted: Mon May 22, 2017 07:30 PM
Sometimes you just gotta say out loud, what were they thinking?
Recently I had gotten a homebuilt bug back that I had given to my cousin who had bigger plans than he was able to put into fruition, however when he had completely disassembled and returned my car, he gave me his parts that he had gathered as well.
Included was an engine, but, yes there's always a butt in there, after research I found that its an H case and not worth the effort to rebuild. Too bad.
I decided to tear it down to see what, if anything, I can use off it.
Boy, some people should never do bug work, or maybe this is what they were learning on?
Both heads appear cracked into the spark plug holes. Engine was running so rich that everything is coated in black carbon. 3 studs are screwed, but hey they jb welded one back in. LOL
Pistons and cylinders are huge compared to my 1600cc set I'm planing on building an engine from so I'm not sure what they are yet. Can't believe they spent the money to machine the case for them. Not sure if a hone can clean the cylinders up enough to make them useable. Future attempt or trade parts. We'll see. They had several spacers under the jugs, so either the compression was too high, or they didn't know what they were doing. Which made the pushrods to short, evidenced by the adjustment of the rockers beyond their limits and one adjuster nut found in the valve cover.
They added an external cooler adapter, but didn't put the rubber seals in. Could account for the massive amount of oil caked all over the engine.
So, yeah, I was disappointed, but hey, if anyone needs a block, I have one really cheap. It looks as though it's a stock crank and cam, so I'm stopping there and will split the case if I think I need something from it and will try to get the flywheel off before doing so. I don't have anything that'll touch it i think.
Other parts I acquired, just not sure I'll use, Pedal assembly, turning brakes, dual Weber Carburetors, manifolds and linkage (Explains the Rich Running) etc. I still need to sort out the parts to see what I have.
Fired my bug up, still runs great, except for the flat spot and still very low oil pressure once warmed up (Not like it's going to fix itself). I'm going to adjust the brakes again and bleed them to see if I get a better pedal and maybe drive it around until it's so hot I can roast a weenie in it, the engine blows, or I build another engine from my parts.
Thanks for reading.
5 Admin_AzBaja 8335 Baja Bugs on Wiki need...
285 MusicManiac 255262 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1208 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 2011 Re: Had to go play in ...
0 Northmountainauto 2176 Shop Baja
