Latest: Curtis
Overall: 3613
Visitors: 129
Total: 129
02: Event Calendar
16: Event Calendar
18: Event Calendar
31: Event Calendar
41: Event Calendar
44: Event Calendar
68: Event Calendar
85: Event Calendar
88: Pictures
89: Event Calendar
98: Event Calendar
112: Event Calendar
122: Event Calendar
124: Event Calendar
128: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Bolt on bumper
Bolt on bumper
yellowchev
yellowchev
Post Post subject: Re: Bolt on bumper
Posted: Sat Jan 28, 2017 03:28 AM
Dalton wrote:
I welded lag bolts to the backside of the mounting plates so I don't need to use a wrench on the inside of the car to get the bumper off. the 4 bolts on the mount are also welded to a 1" plate on the inside of the car and fit between the ribs of the fire wall... so I don't smash the stock firewall ribs.
Dalton, thanks for the info. You may have explained this, but does the diamond plate transfer the force from being rear ended back into the chassis? Or is it strong and thick enough to take on a rear end impact? I ultimately want to tie back into something structural so the forces are transferred correctly and not coming through the fire wall. I'll study your pictures some more to wrap my head around it. Thanks everyone for the input so far.
yellowchev
yellowchev
Posted: Sat Jan 28, 2017 03:34 AM
Dalton wrote:
Is the diamond plate missing here?
Post Post subject: Bolt on bumper
Posted: Sat Jan 28, 2017 04:50 AM
Yes, empi #9507. I had one on my car for years without issue before switching to a bus trans. I now run the bug to bus version and it's doing just fine
yellowchev
yellowchev
Posted: Sun Jan 29, 2017 06:51 PM
Awesome! Thanks I'll check it out.
Posted: Mon Jan 30, 2017 02:43 AM
yes... the diamond plate transfer the force from being rear ended back into the chassis it was thick enough... I built the bumper it to tow ... not to take an impact ... it seemed to do fine with no damage from being hit. if I get hit any harder it will start to do damage.... I think.. I did not build in a weak link for an impact... If I need to re-do the bumper I might build a weak link to save the body from damage.
yellowchev
yellowchev
Posted: Mon Jan 30, 2017 01:55 PM
Gotcha. Seems like a sturdy and good looking setup. I might mimick that just for the looks. What was the thickness of the plate again?
Does anyone have pics or could guide me to pics of what the bottom two mounts should look like? I'm lacking a visual on some of the instruction. In my mind it just inserts into the end of the pan where my strap transaxle extensions are. I'd like though to see what's correct and follow that as much as I can.
Posted: Tue Jan 31, 2017 01:01 AM
I went HD... don't like the store bought stuff. Check out the photos on my link... I used 3/4" all thread..
yellowchev
yellowchev
Posted: Tue Jan 31, 2017 01:37 AM
Awesome! I'll check it out
Posted: Tue Jan 31, 2017 02:35 AM
No new posts Projects and Builds Chickenpants' Bumper/Towbar 6 BugZyla.com 8659 Chickenpants' Bumper/T...
 Fri Feb 26, 2010 09:00 PM
BugLife View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper ideas 7 danjones333 5846 front bumper ideas
 Tue Feb 02, 2010 08:26 AM
NAXZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion new front bumper 13 danjones333 6952 new front bumper
 Sat Sep 05, 2009 11:11 PM
danjones333 View latest post
No new posts Projects and Builds How To Install New Rear Suspension Bumper in 69?? 4 glenf 3463 How To Install New Rea...
 Wed Jun 17, 2009 03:54 AM
glenf View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper 3 Dickie 3362 Re: front bumper
 Fri Nov 14, 2008 10:00 PM
jamesr6168 View latest post
