Latest: hulkbaja
Overall: 3594
Visitors: 103
Total: 103
11: Drivers
13: My Account
25: My Account
60: Event Calendar
87: Event Calendar
99: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Bolt on bumper
Bolt on bumper
yellowchev
yellowchev
Post Post subject: Bolt on bumper
Posted: Thu Jan 26, 2017 09:18 PM
Hey guys,
I've got a 70 Baja that has a newer (not sure on the year) transaxle and I have a bolt on bumper from Chirco. When I hold it up to get an idea of how it fits, it's doesn't seem to go in as far as it should. I started looking and it looks like I have some after market brace extensions to hold the transaxle? What do I need to do to properly and securely install the bumper? I'll try and post some pics. Also, bolting the top end of this bumper into the fire wall is giving me some heartburn. Doesn't seem structurally sound. What are your thoughts?
yellowchev
yellowchev
Posted: Thu Jan 26, 2017 09:35 PM
Posted: Thu Jan 26, 2017 10:53 PM
take a pic of the transmission/mount from the side. Parts seem missing to me.
Your concern about the firewall mounted rear bumper is right, it isn't structurally sound if you have nothing behind it, IE a cage. If you do have a cage the common thing to do is either go straight through the firewall and weld to the cage, or sandwhich plates to the firewall, and then to the cage inside. If you don't have a cage in the car, a bumper that ties to the factory shock mounts is much stronger.
yellowchev
yellowchev
Post Post subject: Re: Bolt on bumper
Posted: Fri Jan 27, 2017 06:27 PM
Thanks. im exploring some weld options that would resolve it but your thoughts confirmed what I was thinking.
Posted: Fri Jan 27, 2017 10:51 PM
I mounted 1/4" diamond plate to the fire wall ....
Posted: Fri Jan 27, 2017 10:54 PM
Posted: Fri Jan 27, 2017 10:57 PM
s1053.photobucket.com/...t=3&page=1
Got rear ended last year.... it did not to a thing to the firewall or bumper but put paint on it.... It looked like I did a lot of damage to the other car..
Posted: Fri Jan 27, 2017 11:01 PM
it is hard to see but there are SS bolts all the way around the outside of the firewall to mount it to the car... must be about 50 of them.... you can see only a few of them in the photos... but they go all the way around the outside.
Posted: Fri Jan 27, 2017 11:06 PM
I welded lag bolts to the backside of the mounting plates so I don't need to use a wrench on the inside of the car to get the bumper off. the 4 bolts on the mount are also welded to a 1" plate on the inside of the car and fit between the ribs of the fire wall... so I don't smash the stock firewall ribs.
yellowchev
yellowchev
Posted: Fri Jan 27, 2017 11:13 PM
Here is the bottom side
yellowchev
yellowchev
Posted: Fri Jan 27, 2017 11:14 PM
Thanks dalton I'll have a look tonight and maybe have some more questions.
cap the ends of the bumper so it does not rust from the inside out...
Posted: Fri Jan 27, 2017 11:17 PM
I use stair well caps...
they are cheep and look very nice...
Posted: Sat Jan 28, 2017 02:51 AM
I really don't like your transmission mount. Okay for a street car but not for a Baja. Invest ina nice solid mount with a bell housing strap that actually bolts to the mound, and not wraps around the transmission. With the current mount, if you put a bumper on, the motor is going to be lower than the bumper and that means a skid plate is useless. The whole point is to protect the motor with the bumper that means the bottom too
yellowchev
yellowchev
Posted: Sat Jan 28, 2017 03:15 AM
I'm with ya. I'm really glad I finally got this car but what was sold to me in writing sounded a lot better than what I got. Plus being new to VWs I didn't have the eye I needed to make an informed buy. But I'm only in $4300-$4500 with some major improvements so hopefully I can put a few more grand in it and love this car.
Where could I find a solid mount like you're referring to? Empi sell something good?
No new posts Projects and Builds Chickenpants' Bumper/Towbar 6 BugZyla.com 7759 Chickenpants' Bumper/T...
 Fri Feb 26, 2010 09:00 PM
BugLife View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper ideas 7 danjones333 5168 front bumper ideas
 Tue Feb 02, 2010 08:26 AM
NAXZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion new front bumper 13 danjones333 5590 new front bumper
 Sat Sep 05, 2009 11:11 PM
danjones333 View latest post
No new posts Projects and Builds How To Install New Rear Suspension Bumper in 69?? 4 glenf 3063 How To Install New Rea...
 Wed Jun 17, 2009 03:54 AM
glenf View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper 3 Dickie 2848 Re: front bumper
 Fri Nov 14, 2008 10:00 PM
jamesr6168 View latest post
