Latest: Curtis
Overall: 3613
Visitors: 144
Total: 144
08: Event Calendar
11: Event Calendar
12: Pictures
22: Event Calendar
29: Event Calendar
39: Event Calendar
44: Event Calendar
46: Event Calendar
112: Event Calendar
113: Event Calendar
124: Event Calendar
130: Event Calendar
133: Event Calendar
136: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- Axle's needed
Axle's needed
DerekT
DerekT
Post Post subject: Axle's needed
Posted: Mon Dec 05, 2016 10:18 PM
Looking for a pair of 19 1/4" axles for 3x3 set up. I bought the whole set up from a guy but his axles are 21" so to long.
Posted: Tue Dec 06, 2016 02:55 AM
cut them down to size...
DerekT
DerekT
Post Post subject: Re: Axle's needed
Posted: Tue Dec 06, 2016 11:19 PM
There is a ser clip on the end that holds on the bearing witch would have to be cut off an then you also wouldnt have the 2 inches of slide for the bearings.
gman3850
Colonel
Colonel
gman3850
Posted: Wed Dec 07, 2016 10:15 AM
Are u running 930 or t2. If t2 I've got a set of sway-a-waus
DerekT
DerekT
Posted: Wed Dec 07, 2016 05:38 PM
I have T2 CV's. Will sway axles work the same. This is my first VW.
DerekT
DerekT
Posted: Wed Dec 07, 2016 05:39 PM
I have T2 CV'S, are sway away axles the same. This is my first VW so learning the what's what.
Thanks Derek
gman3850
Colonel
Colonel
gman3850
Posted: Wed Dec 07, 2016 05:44 PM
Sway away has axles for every vw varroent. T1-bug t-2/4 bus/thing/Porsche 930 race cvs.
DerekT
DerekT
Posted: Wed Dec 07, 2016 06:12 PM
SO you have a set 19 1/4", How much are you looking to get for them.
Thanks.
gman3850
Colonel
Colonel
gman3850
Posted: Wed Dec 07, 2016 06:18 PM
200$. New they cost 300. Plus they come with some lobro t2 cvs
DerekT
DerekT
Posted: Wed Dec 07, 2016 06:20 PM
Where are you located.
gman3850
Colonel
Colonel
gman3850
Posted: Wed Dec 07, 2016 06:24 PM
Gilbert az
DerekT
DerekT
Posted: Wed Dec 07, 2016 07:33 PM
Are you able to take a photo of them. I'm sure they will work I would just hate to buy them have them shipped and then not. I'm on a budget for this car. And thanks for all the input. Also I have type 2 cv's on the tranny and type one stub axles. So I will just need to take my type 1 CV's off and put them on the sway-away axle.
Posted: Wed Dec 07, 2016 08:29 PM
Your type 1 cv's will not work on your 3x3s. They will bind no matter what kind of travel you set your suspension for. They don't have enough articulation in them to be moved back 3 inches from the stock location and then cycle through the suspension travel.
I've tried, it will break the cages in the cv's repeatedly
Posted: Thu Dec 08, 2016 12:56 AM
You can make a new snap ring grove. it would be a lot cheaper than buying a new Axle's.. look up a local machine shop to do the work.
Posted: Thu Dec 08, 2016 01:19 AM
Go 930's not T2's you will be a lot happier ... you need to get the kit from Empi that has the smaller balls for the CV's.. I don't run the "race cages" in my 930's any more ... there are a few reasons why:
1) they tend to "Click" bad.
2) they run hotter than stock cages.
3) I rather replace a 930 CV than blow something up in my trans.
Now with that being said.... I do run race cages on the inside CV on my rail so when I do blow a CV it is the outer CV that runs a stock cage... But my inner CV with a race cage I am running smaller balls and I have done mods to the inner race inside the CV and the race cage to make them work better... if you have access to a mill this is the way to go, but I rather replace a CV than a transaxle.
pound for pound... Now with all the mods and "fixes" that can be done to CV's... I just run stock cages with the sharp edges sanded down and install the smaller balls and carry 2 spares 930 CV's.. if you "click " on my "more photos" it will show how to pack and store a CV so they will never rust the inside.
No new posts Projects and Builds NEEDED! Door Handles 7 wideopenmotorsports 6757 NEEDED! Door Handles
 Sun Nov 22, 2015 06:27 AM
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 5476 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion tow bar needed
like now
2 gman3850 1957 tow bar needed
 Sat Sep 14, 2013 10:57 PM
gman3850 View latest post
49 wideopenmotorsports 36818 Pit Help Needed For Of...
 Tue Jan 08, 2013 06:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 3521 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
