Visitors: 127
Total: 127
41: Links
51: Home
100: Event Calendar
123: Home
126: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- baja handy update
baja handy update
Post Post subject: baja handy update
Posted: Fri Dec 22, 2006 05:33 AM
ok I looked at the motor.
it does work out to bein a 2007cc.
the valves are recessing into the heads . to far for machine work.
the cam is an engle 110
the crank has an issue with the main bearing (rear?) self welding itself on.
the case may not be good where the main bearing (rear?) f*d up and grooved it a lot.
carbs are usable.
exhaust is good.
we are goin to 94mm pistons for a 2200cc.
gonna look into havin the crank machined.
let me know if any of ya think we can salvage the heads.
see pics (not the best, but they are pics)....
need diff pics? let me know.
bajasam96
bajasam96
Post Post subject: Re: baja handy update
Posted: Fri Dec 22, 2006 07:01 AM
I wouldn't worry a bit about the heads. If they really are recessed in too much just put new seats in them, But I but your fine. alot of People grind their seats down so the valve sits deep like that. Your case scares the hell outta me though! thats alot of metal to have floading around hopefully its mostly from your bearings and not the case or crank. Make sure if you decide to reuse it, have it thoroughly inspected but the oldest most anal VW guru arizona has to offer. It may turn out fine, but theres alot riding on it if your wrong...
Posted: Fri Dec 22, 2006 09:28 AM
Man, That case is hammered!!!!!!! I would say by looking at the pics its not salvageable. If you need a case, I have one thats ready to go. Machined for 94s, drilled for full flow, been vated and line bore checked. Also welded behind #3. Just call me if you need it.
Posted: Fri Dec 22, 2006 04:32 PM
I will take you up on the case there Daryll.
think I should have the valves redone or just get new heads??
Posted: Fri Dec 22, 2006 05:57 PM
Can you bring the heads by so I can take a look at them? Its hard to say without actually looking them over.
Posted: Fri Dec 22, 2006 06:10 PM
we agreed to wait till after Christmas to tackle the motor.
Ill get em for ya next week big D.
Posted: Sat Dec 23, 2006 12:13 AM
We have the makings for one hugely brite bon fire. I now have 2 crap cases and Bajafun has one.
6Rage
6Rage
Posted: Sun Dec 24, 2006 04:32 AM
Well then take all three cases and make urself 1 case that is a flat 8 or 12 even, sell it on ebay as a one of a kind and turn around and buy somethin with the money you made.
My other cars a UDLX
Need to know the method to my madness? email me I'll tell ya bajarage @ hotmail.com.
azhunter
azhunter
Posted: Mon Jan 01, 2007 02:25 AM
found this on samba, I know the guy selling it. he's an old drag racing guy.
www.thesamba.com/vw/cl...?id=401818
check it out kevin
Posted: Mon Jan 01, 2007 04:40 AM
thx but I have a deal worked with BIG D Very Happy
azhunter
azhunter
Posted: Mon Jan 01, 2007 05:11 AM
kewl
5 Admin_AzBaja 6746 Baja Bugs on Wiki need...
1568 mufasavnvmc 998092 Re: what did you do to...
285 MusicManiac 240998 Re: Baja sightings
0 Northmountainauto 1511 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4085 Baja hiding in Chandle...
