Latest: xbluegto
Overall: 3573
Visitors: 126
Total: 126
08: Event Calendar
15: Pictures
41: Event Calendar
63: Pictures
64: Event Calendar
65: Garage
97: Event Calendar
111: My Account
Baja Forums -:- AzBaja.com Members -:- New Members -:- Air filter issues
Air filter issues
DerekT
DerekT
Post Post subject: Air filter issues
Posted: Fri Sep 16, 2016 03:34 PM
Running a single carb, 40 webber with oval filter. I use the standard dust sock / cover over the filter but still get dust in the carb . What kind of canister or foam filter would be better. It seams like the rear tires just cause a dust bowl around the motor. Any advice on what else to run.
Posted: Fri Sep 16, 2016 04:25 PM
I run a UMP aluminum canister filter with the aluminum air box. The filter is mounted inside the back window.
Before I ran this, I had a 9" tall filter with a billet lid and base, and an R2C filter and outerwear. The R2C filter is an oil-less filter and does the best job of keeping the dirt out. Not all of it but much better than a K&N. The nice thing about the R2C is you just clean it by blowing it out/tapping the dirt out.
What are you running for a filter lid and base? I've seen the cheaper stamped chrome ones not seal because they're too flimsy when you tighten them down.
DerekT
DerekT
Post Post subject: Re: Air filter issues
Posted: Fri Sep 16, 2016 09:55 PM
I have just the standard filter with that cheap chrome top and have the outer wear. I like what you are using but I have the back seat for my kids to ride in. Would have to figure out and out side mount.
New to the site so trying to figure out to add photos of my baja to the questions.
Thanks for the reply.
Posted: Fri Sep 16, 2016 11:46 PM
Most of us use photobucket our photos. then you just copy and past the IMG code.
My car is full race now, no windows, only 2 seats, etc. I have had my UMP for 6 months and have never had to clean the filter. I still check it but no dirt is getting through. It would be very easy to mount one on the back cage somewhere, I just preferred to put mine inside the car away from hazards (crashing, other racers, etc.)
Dalton has one and it is mounted up on his roof rack, kind of like a jeep snorkel.
DerekT
DerekT
Posted: Wed Sep 21, 2016 10:17 PM
Posted: Wed Sep 21, 2016 11:02 PM
Sweet ride! I can see your pic so looks like you figured it out
Posted: Fri Sep 23, 2016 01:56 PM
Posted: Fri Sep 23, 2016 01:57 PM
put the air cleaner up top.
Posted: Sun Oct 02, 2016 07:50 PM
Unless you need the rear parcel area, put it inside the car.
See my build below.
azbaja.com/ForumsPro/v...rt=45.html
Last edited by wideopenmotorsports on Sun Oct 02, 2016 07:54 PM; edited 1 times in total
Posted: Sun Oct 02, 2016 10:06 PM
I have found if you put it inside the car... you will hear the motor a lot more thru the air cleaner.
Posted: Sun Oct 02, 2016 10:38 PM
How many cars have you put the air cleaner in the car? I have done it wit three and see no real difference.
Posted: Mon Oct 03, 2016 01:59 PM
I have put it in One... and that's all it took.
you are putting it into a open race car with no windows that is why you cant hear it..
No new posts VW Volkswagen & Baja Bug General Discussion Remote Oil Filter
Where is the best location?
4 Adub 1888 Remote Oil Filter
 Wed Feb 15, 2017 10:31 PM
Adub View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 3643 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
No new posts VW Volkswagen & Baja Bug General Discussion [ Poll ] Oil Filter or Not to Oil Filter 4 ghs215 2276 Oil Filter or Not to O...
 Fri Nov 13, 2015 03:46 AM
Really bad issues
4 Pointvirus 2264 Clutch Issues
 Mon Dec 03, 2012 07:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion Replacing air filter
Breather tube?
3 pschneider 3491 Re: Replacing air filt...
 Sun Jun 13, 2010 04:03 PM
Rickman View latest post
