Visitors: 144
Total: 144
05: Event Calendar
18: Event Calendar
41: Pictures
46: Pictures
62: Event Calendar
123: Event Calendar
124: My Account
128: My Account
131: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- New father/son budget build
Azdrtdog
Azdrtdog
Post Post subject: New father/son budget build
Posted: Fri Jul 22, 2016 10:27 PM
IMG]http://i965.photobucket.com/albums/ae132/azdrtdog/image_4.jpeg[/IMG]
So this is the new father/son project that I hope get running/driving for a maximum budget of $750, I spent $500 today buying this off Craig's and I'm hoping to finish it for another $250. First steps are teaching the boy how to check and repack wheel bearings and cv's then brake system and so forth.
I'll post up pics and part costs as it comes together, I plan on stealing as much stuff as I can from my friends spare parts and insulting people just enough on Craig's not to make enemies lol, should be fun
Azdrtdog
Azdrtdog
Posted: Wed Oct 12, 2016 10:05 PM
Just an update now that we are starting this build, I told the kid we could build it in time for his birth day on the 27th and I'll take him and his buddy out to play with it that weekend. Pulled the motor becuase it had to come out to check everything and I'm going to borrow a SP 1600 till I have more time to source everything for his, end play is good so I'm going to pull heads and see how fresh it is and maybe I'll find some DP heads and build a proper motor. I plan on going through cv's, bearings, gear oil and rear brakes this weekend since the motor is turn key, after I have drive train the wiring and plumbing is a breeze
Azdrtdog
Azdrtdog
Posted: Thu Oct 13, 2016 02:13 AM
Just picked up the motor, needs a few pieces but runs good
Azdrtdog
Azdrtdog
Posted: Fri Oct 14, 2016 02:10 AM
Pulling axles for service and boots
Azdrtdog
Azdrtdog
Posted: Fri Oct 14, 2016 04:49 PM
Pulled the tins tightened the case up to avoid oil leaks and blew the dirt outa the oil cooler fins as a precaution.
Azdrtdog
Azdrtdog
Posted: Mon Oct 17, 2016 12:21 AM
Got it running and it shifts through the gears, spent about $58 in various parts and fluids to get this far. Ive been pretty lucky digging through a few garages for parts and I'm not done yet.
Cleaned and packed the cv's, I'll reinstall after the wheel bearings and brakes get checked out, new boots woohoo. The rear torsion is a +6" so I'm running 19.25" axles with stock boxed arms.
Azdrtdog
Azdrtdog
Posted: Thu Oct 20, 2016 02:43 AM
another garage score, exhaust and belt I'll use now and save the DP heads for a later upgrade since they need work. Have the clutch working, throttle cable run but needs couple mounting points welded in and the rear brakes plumbed waiting on wheel cylinder inspection before I fill master
Azdrtdog
Azdrtdog
Posted: Fri Oct 21, 2016 11:48 PM
And the work continues
Have the exhaust on and belt
Bending up the brake lines and fitting it all together. Going to cut the flat strap out use angle iron on seat base
Masters are in, still need a tab for throttle cable
Typical VW brakes... I think the spider webs come factory
Azdrtdog
Azdrtdog
Posted: Sun Oct 23, 2016 12:19 AM
installed axles new wheel cylinders and serviced bearings today and she's running of the fuel tank
Started roughing in the wiring, used 8' of 7 wire to make things easier. It starts off the key now. Spent another $75 today for wiring,switch,wheel cylinders and a few more small pieces, $128 total
TINMAN
TINMAN
Post Post subject: Re: New father/son budget build
Posted: Sun Oct 23, 2016 01:18 AM
Great to see family coming together around a project car your son will never forget this time with you. see if you can get some seats and belts in the car and bring it out to the hassayampa for a test run
TRUMP 2020
Azdrtdog
Azdrtdog
Posted: Sun Oct 23, 2016 02:10 AM
I'm hoping to get it moving tomorrow and do a shake down next weekend for the play day run
Posted: Sun Oct 23, 2016 06:59 AM
Nice job
Azdrtdog
Azdrtdog
Posted: Mon Oct 24, 2016 12:47 AM
As promised.. It drove up on the trailer today
Azdrtdog
Azdrtdog
Posted: Mon Oct 24, 2016 01:36 AM
^^^click play^^^This was yesterday just after installing switch
Cut the old seat mounts out and made up the tabs for brakes lines and throttle cable today. She has a date with the electric glue gun tomorrow so should have seats and belts when I'm done
Posted: Mon Oct 24, 2016 12:58 PM
Azdrtdog wrote:
[T
Who needs seat mounts anyways.. Love the idea of "glue gun-ing" the seats and seat belts in... Keep it simple.
26 1963BAJA 9417 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5890 New Class 11 Build - P...
101 SuburbanLegend 144252 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts Projects and Builds Old school-ish budget buggy 7 pepeazul 6121 Old school-ish budget ...
 Fri Jul 17, 2015 02:29 PM
61 1450bug 57272 1450Bug Build
 Fri Jan 23, 2015 03:41 AM
