Visitors: 209
Total: 209
02: Contact Admin
41: Event Calendar
52: Links
59: Event Calendar
61: Event Calendar
62: Event Calendar
63: Event Calendar
64: Event Calendar
65: Event Calendar
67: Event Calendar
68: Event Calendar
75: Event Calendar
90: Event Calendar
96: Event Calendar
106: Event Calendar
107: Event Calendar
108: Event Calendar
111: Event Calendar
112: Event Calendar
115: Event Calendar
116: Event Calendar
117: Event Calendar
118: Event Calendar
119: Event Calendar
120: Event Calendar
121: Event Calendar
122: Event Calendar
123: Event Calendar
126: Event Calendar
127: Event Calendar
140: Pictures
146: Event Calendar
147: Event Calendar
148: Event Calendar
149: Event Calendar
150: Event Calendar
151: Event Calendar
154: Baja Forums
158: Baja Forums
159: Event Calendar
164: Baja Forums
177: Baja Forums
178: Baja Forums
179: Baja Forums
181: Baja Forums
185: Baja Forums
188: Baja Forums
191: Baja Forums
193: Baja Forums
194: Baja Forums
195: Baja Forums
196: Baja Forums
197: AMAZON.com
198: Baja Forums
200: Event Calendar
201: Baja Forums
202: Event Calendar
203: Event Calendar
204: Event Calendar
205: Event Calendar
206: Event Calendar
207: Event Calendar
208: Baja Forums
209: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Suspension Help
Suspension Help
RDMINAZ
RDMINAZ
Post Post subject: Suspension Help
Posted: Sat Jun 18, 2016 07:31 PM
Thanks been super busy the past few months. Still looking for someone that would like to earn some side cash with the suspension prob. on the baja I bought. Previous owner has the thing so torqued up it rides like a tank! Ball joint F.E. w/ adjusters that don't seem to work and the rear IRS setup will loosen fillings, it's that stiff. Soooo if anyone has ideas/solutions please let me know. Would like to go to link pin if swap out is within budget.
Posted: Sun Jun 19, 2016 06:56 PM
I might be able to help.
Dalton 602-617-6869
Sandrailbuilder
Sandrailbuilder
Posted: Sun Jul 10, 2016 07:12 AM
I had the same problem on mine, I fount that someone had replaced the bearings in the beam with those polyurethane bushings. The bushings didn't fit correctly and were crimping down an the arms and made it solid as a rock. I machined the bushings slightly, and trimmed the overall length down slightly. I also greased the bushings and it works like factory now.
Sandrailbuilder
Sandrailbuilder
Azdrtdog
Azdrtdog
Posted: Mon Jul 18, 2016 03:05 PM
Bushings need to be reamed when installed, foddrills has the tool and they will loan it out like Oriellys you just pay for it till you return
Azdrtdog
Azdrtdog
Posted: Mon Jul 18, 2016 03:06 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja suspension upgrade on All Girls Garage TV show May 3rd. 4 BugZyla.com 4778 Baja suspension upgrad...
 Tue May 13, 2014 12:35 PM
irs,swingaxle
3 desertbaja 3234 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
No new posts VW Volkswagen & Baja Bug General Discussion Rear suspension question 5 FLBaja 3930 Rear suspension questi...
 Tue Jul 26, 2011 12:08 AM
No new posts Projects and Builds Chris from Vegas suspension upgrade.
21 BugZyla.com 15076 Re: Chris from Vegas s...
 Wed Jul 20, 2011 07:05 PM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Suspension
Really Stiff warrior beam
4 Cooop! 2744 Re: Suspension
 Fri Jan 14, 2011 03:58 PM
