Latest: Curtis
Overall: 3613
Visitors: 142
Total: 142
02: Event Calendar
03: Pictures
08: Home
21: Pictures
29: Event Calendar
44: Home
45: Home
52: Event Calendar
63: Event Calendar
71: Event Calendar
75: Event Calendar
78: Event Calendar
79: Event Calendar
82: Event Calendar
87: Event Calendar
101: Event Calendar
103: Contact Admin
106: Event Calendar
107: Event Calendar
121: Event Calendar
125: Event Calendar
135: Event Calendar
139: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wiring
Wiring
bugzapper
bugzapper
Post Post subject: Wiring
Posted: Mon Jun 27, 2016 06:56 PM
Need help matching up wires from efi harness to carb motor specifically for the regulator and ignition system
"killing time isnt murder -- its suicide"
Posted: Tue Jun 28, 2016 02:21 AM
more information
bugzapper
bugzapper
Post Post subject: Re: Wiring
Posted: Tue Jun 28, 2016 04:18 AM
which wires of the "efi" harness do i use on the older carb motor? specifically which wires go where? part of the problem is that the efi car has different wire connections and plugs than the motor so im having difficulty matching everything up would really like at least minimum for it to run then go from there..i have not found a decent diagram that explains the efi wires ....it seems like i just need a hot wire into regulator and from regulator to ignition and i think the fuel cutoff/ but that comes off the coil right?...negative side? and my hot for the coil comes from?..the key/
bugzapper
bugzapper
Posted: Tue Jun 28, 2016 04:22 AM
how do i know if the efi generator was internally or externally regulated?
Posted: Tue Jun 28, 2016 03:16 PM
Post photo...
I don't understand "efi generator"
all VW air cooled generators are externally regulated.
VW alternators .... some are internally regulated some are not
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 7491 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
28 seanoflinn1 13914 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Think I might have a wiring problem? 5 Roadrunner 3562 Re: Think I might have...
 Sun Aug 03, 2008 10:35 PM
sandshark View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VDO Guage Wiring Diagrams 1 BugZyla.com 3093 Re: VDO Guage Wiring D...
 Sat Feb 16, 2008 11:21 PM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion wiring 10 caversmoon 6264 Re: wiring
 Sun Sep 16, 2007 06:49 PM
