Visitors: 100
Total: 100
22: Event Calendar
31: My Account
45: Event Calendar
54: Event Calendar
55: My Account
65: Pictures
68: Event Calendar
77: My Account
97: Contact Admin
98: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- how much curb weight can a VW chassis/susp handle?
olly
olly
Post Post subject: how much curb weight can a VW chassis/susp handle?
Posted: Fri Jun 24, 2016 09:26 AM
Hi everyone. Noob here.
I'm considering using a VW chassis for a customized project, and the end result is likely to be heavier than a normal Baja bug. Drivetrain will be something non-stock and probably 3+ liters of displacement.
Are the standard VW suspensions (IRS rear + torsion bar front) good for 3000 pounds of vehicle? (That figure is the final weight including the VW chassis parts, fuel, passengers, etc.)
The vehicle could be subjected to some off-roading but probably not too severe by Baja standards. Maybe some driving moderately fast on uneven dirt/gravel roads. No 80mph through the desert stuff.
With cars/trucks just about anything can be modified to put up with ridiculous abuse if you replace & custom-build enough of it. But if you have to replace most of the setup to make it work then you probably picked the wrong starting point IMO.
Is the VW chassis a worthwhile starting point for something that heavy?
What kind of stuff usually breaks first? The suspension arms? Bearings? Pivot points?
Thanks for any responses.
Azdrtdog
Azdrtdog
Posted: Tue Jun 28, 2016 04:53 PM
Might want to ask dalton, his bug probly weighs close to 3k lbs with a the shit he has welded bolted glued screwed and tie wired to it.
Posted: Tue Jun 28, 2016 05:34 PM
I am around 2700lb with just me in it. no camping gear. with a standard day run load on the car.
No new posts Projects and Builds American Motorsports Tube Chassis Baja
Cabriolet,1.75" DOM Tube Chassis, Honda 3.5, Mendeola, Gear1
4 AmericanMotorsports 4621 American Motorsports T...
 Thu Aug 14, 2014 03:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion 71 Baja on 78 Bus chassis 9 biofuelbajaman 16705 71 Baja on 78 Bus chas...
 Fri Jan 11, 2013 03:41 PM
No new posts VW Volkswagen & Baja Bug General Discussion Thing Kit/Car on 59 Chassis 5 Conundrum 4861 Thing Kit/Car on 59 Ch...
 Sat Jul 14, 2012 11:05 PM
No new posts Projects and Builds Precision Chassis Works Baja BUild
my first baja build ever.
22 PrecisionChassisWorks 23794 Re: Precision Chassis ...
 Wed Dec 16, 2009 06:46 PM
Hedrock View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Will a 5 lug drum fit a 4 lug chassis? 2 zx10r203 1581 Re: Will a 5 lug drum ...
 Tue Mar 25, 2008 04:44 PM
oldfart View latest post
