Visitors: 133
Total: 133
08: Pictures
09: Pictures
39: Event Calendar
40: Pictures
52: Event Calendar
67: Home
81: Pictures
91: Pictures
93: Home
131: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Toyota 3tc swap
Toyota 3tc swap
Sandrailbuilder
Sandrailbuilder
Post Post subject: Toyota 3tc swap
Posted: Sat Apr 02, 2016 05:04 AM
Hello all, I am building a baja bug.....slowly. I bought a toyota 3tc engine. Just curious if anyone has run this engine?? Also I am looking for the adapter plate and am hoping not to have to shell out $500 to KEP. If anyone knows where to find n adapter, and knows about this swap and engine, I am open to any advise. Thx
Posted: Sun Apr 03, 2016 01:39 PM
is that Toyota 3tc the one that was out on Craig's list? Go with the 228mm flywheel ... you will be a lot happier with it if you can.
Sandrailbuilder
Sandrailbuilder
Posted: Sun Apr 03, 2016 02:35 PM
It was in the Tucson Craigslist about two weeks ago, I did see there was one in Phoenix too. Have you had experience with this engine? I have none, I read it is a really good engine. It's seems to be a much simpler swap than having a computer to deal with. It also doesn't make a lot of horsepower so I am not as worried about the trans. I hoping to get away with a stock type 1 irs for a while. Until I can afford a bus box
Posted: Tue Apr 05, 2016 01:01 PM
my first swap was a Toyota 2.2R.. I did not want to mess with the computer either ... Never looked back... Now... Full blown water pumper with computers and everything.
I have a few pointers.. that will save you time and money in the long run..
start out with putting the radiator up front in the air flow. its the only way it will cool right. if you don't, you will have radiator creep... or remove the rear window and mount it there seems to work.
once you go water pumper ... you will never go back ...
with that being said.... start out with an eco tech 2.2l ... they are cheep and there are a bunch of fokes that can send you a wire kit that plugs right into the computer with marked wires for the install. very simple ...
if you are going to start out with a type 1 trans... you will need to stay with the 200mm flywheel, don't go past a stage 1 presser plate with a cable cluch.
Sandrailbuilder
Sandrailbuilder
Post Post subject: Re: Toyota 3tc swap
Posted: Tue Apr 05, 2016 02:47 PM
How did you run the coolant lines to the front? If I run them underneath I would be concerned about crushing them on a rock, but I wouldn't want them running through the cabin either during the summer it got enough as is!
Posted: Wed Apr 06, 2016 01:24 AM
There are a few ways I can think of...
we used copper pipe In one install.. it was nice because it had nice 90 and 45 to put on it. but it was week.
if I had a cage I would weld it into part of the cage inside the cab ... it wont sweat that much heat... seen it done on a few rails.. just don't grab the pipe.
or use 1 1/4 hose .. thick form somewhere like from Hose power run inside the cab. I run my heater lines inside my cab using 3/4 hose.. gets hot but I don't notice it unless I grab the line.
on a simple Baja.. use Black pipe under the car.. the stuff can take a hit.. nice 90 and 45 right off the shelf.. run it on both sides of the tunnel all the way up to protect the pan. if you rip a hole in black pipe you have other problems.. its kinda heavy.. but ugly tuff. if you use black pipe have them thread them deep... Home Depot will only thread them a few turns ... I have to watch them and have them keep going until I get about 3/4" into the other piece.. I bought my own pipe threader because I was tired of running back to Home Depot..
Kreed
Kreed
Posted: Fri May 13, 2016 05:57 PM
I have had no problems with my radiator set up in the back. You can check it out here if you want.
Sandrailbuilder
Sandrailbuilder
Posted: Sat May 14, 2016 02:48 AM
Thank you for the pic, I am planning on trying something really similar to what you did. What transaxle are you using? How do you put a link to a picture? Or upload pictures?
Kreed
Kreed
Posted: Sun May 15, 2016 01:09 AM
I'm using a Bus Transaxle built by Dons Bus Box. It has racing gears in it for strength. You can check out my threads in Engines and Transaxles and also project builds. The best way I can figure out how to attach pictures is to upload them into the picture section of this site, then once you open them you can copy and paste the link like I did. I know there is another way but I do not know how to do it.
Sandrailbuilder
Sandrailbuilder
Posted: Wed Dec 14, 2016 07:06 PM
I have my bug running finally. I have a few things to finish and paint. I want to go on some of these runs you all go on. I
T runs nice, I'm pretty happy with it. It's a lot of fun so far
Posted: Thu Dec 15, 2016 01:33 AM
come on up for the New Years campout..
Sandrailbuilder
Sandrailbuilder
Posted: Thu Dec 15, 2016 01:39 AM
Where is that going to be? I don't think i have enough time off over new year's to go anywhere. And my bug needs tires before I can go anywhere. Ive been looking all over Craigslist trying to find some
Northmountainauto
Northmountainauto
Posted: Wed Apr 18, 2018 09:22 PM
This is the car I bought! Cool to find info on the build!
Posted: Wed Apr 18, 2018 10:08 PM
Cool any new photos?
Northmountainauto
Northmountainauto
Posted: Wed Apr 18, 2018 10:21 PM
I’m not sure how to post them is there a tutorial for posting pictures?
6 AZOffroadSwapmeet 3818 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 02:37 PM
5 bajabuggy69 4894 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VW TDI Engine swap? 8 Grunt-0341 6504 VW TDI Engine swap?
 Thu May 02, 2013 01:06 PM
blg4351 View latest post
No new posts Events and Get Togethers World Wide Michigan Buggy Builders Swap Meet 0 Lucky7-11 2756 Michigan Buggy Builder...
 Fri Feb 01, 2013 02:45 AM
Lucky7-11 View latest post
No new posts Events and Get Togethers World Wide Automotive swap meet 4 Peajay 3330 Automotive swap meet
 Sat Jan 05, 2013 07:07 PM
