Visitors: 107
Total: 107
43: Pictures
47: Event Calendar
99: Pictures
100: Pictures
101: Event Calendar
Baja Forums -:- Off-Road & VW Based Clubs (4x4, ATV, Jeep, Motorcycle) -:- Events and Get Togethers World Wide -:- Annual 400 mile camp out may 21-22 2016. SAT-SUN
Azdrtdog
Azdrtdog
Post Post subject: Annual 400 mile camp out may 21-22 2016. SAT-SUN
Posted: Thu Feb 11, 2016 04:16 AM
Let's get planning, had a lot of fun last year. Hope there is a wagon train of cars this year Very Happy back to the traditional weekend before Memorial Day weekend
Post Post subject: Annual 400 mile camp out may 14-15 2016
Posted: Thu Feb 11, 2016 02:24 PM
Get Gas... check.
Get beer... check.
load car... check.
find map... check.
Posted: Thu Feb 11, 2016 05:20 PM
Baja is finally done and this event is the same weekend as the Sandstorm 300 race. Maybe next time guys.
Azdrtdog
Azdrtdog
Post Post subject: Re: Annual 400 mile camp out may 14-15 2016
Posted: Thu Feb 11, 2016 07:29 PM
Dalton wrote:
Get Gas... check.
Get beer... check.
load car... check.
find map... check.
Mine is more like, buy 930's install 930's....check
Change bump,strap and shock location for anticipated increase in travel....check
Gusset lower tube to torsion housing.....check
Get 350# springs for front installed....check
Remember all the other stuff after I'm on trail.....check
Posted: Fri Feb 12, 2016 04:02 AM
well... to be honest... right now my list is ugly on both the rail and the Baja.
My post run inspection of the rail found more damage I need to address before it goes out again... just a few things I knew were getting close to needing repair but were ok for now.. well my armor needs attention and a crack in my radiator is starting to leak when the car is cold and I need to replace a seal that is leaking oil on my power steering not bad but it bothers me. that's why I switch from the RV and the rail to focus on the Baja.. the Baja is a lot more work than I thought but it will be the faster fix of both the rail or RV. I need to get some more wheel time on the Baja before I take it deep,,, I need to work the bugs out.
Posted: Fri Feb 12, 2016 03:40 PM
the date is wrong... its May 20th and 21st.
Azdrtdog
Azdrtdog
Posted: Fri Feb 12, 2016 05:08 PM
The date is what it was last year, if y'all want to move it back to memorial weekend I don't think anyone's complaining (dalton). But it does clear up the conflict for wide open
Posted: Sat Feb 13, 2016 02:37 AM
Memorial weekend is the 28th - 30th
Azdrtdog
Azdrtdog
Posted: Sat Feb 13, 2016 02:47 AM
See..... We need planning! I'm good with the 20-21st if that's the day it should be on. I don't plan for next week so 2 months from now I'm sure I can make work. I ordered my 930 kit today, got it for $425 free ship
Posted: Sat Feb 13, 2016 03:36 PM
does the kit come with the smaller balls
Azdrtdog
Azdrtdog
Posted: Sat Feb 13, 2016 03:42 PM
No clue, cheap empi kit that claims 25 degrees.
Azdrtdog
Azdrtdog
Post Post subject: Annual 400 mile camp out may 20-21 2016
Posted: Wed Mar 16, 2016 03:13 AM
Alright, 2 weeks later my quick and easy 930 cv swap is finally done. Is fri- sat the correct days for the 400?? I thought it was on sat morn to sun afternoon, that would be the 21-22 of May
azdesertrat87
azdesertrat87
Posted: Fri Mar 18, 2016 02:55 AM
I'm not sure of the exact date's but normally it's a Sat morning to Sun mid afternoon FRIGGING Awsome run! Since I live on the polar oposite of the starting point I usually camp up at the fourth spring, that way I can sleep in a little break camp and start to listen to chatter on the radio. that way I have an idea how soon there going to pass by me, then I simply jump in line and away we go!
ikill6453
ikill6453
Post Post subject: Re: Annual 400 mile camp out may 20-21 2016
Posted: Sun Mar 20, 2016 04:04 PM
can someone please check the date..... 20-21 is a Friday-Saturday....correct?
don't we want the Saturday-sunday the 21-22 of may, 2016......
or did daylight savings really mess me up( since we in az don't change) cause that would explain things.
let me know cause work will need a written day off excuse from somebody who cares.
ikill6453
ikill6453
Posted: Sun Mar 20, 2016 04:05 PM
No new posts Events and Get Togethers World Wide 2018 AZBaja 9th Annual Play Day, Date.... 0 Dirtjunkie 1430 2018 AZBaja 9th Annual...
 Wed May 23, 2018 03:59 PM
No new posts Events and Get Togethers World Wide Camp out 1 Dalton 1366 Camp out
 Tue Nov 07, 2017 05:02 PM
No new posts Events and Get Togethers World Wide 8th Annual AzBaja Playday 2017
October 6,7,8 2017
19 Dirtjunkie 6816 Re: 8th Annual AzBaja ...
 Tue Oct 10, 2017 06:49 PM
Sat November 5th
83 Dirtjunkie 28181 Official 2016 Hassaymp...
 Tue Jan 31, 2017 01:25 AM
18 Dirtjunkie 6908 Official 2016 Hassaymp...
 Tue Nov 08, 2016 02:49 AM
