Latest: hulkbaja
Overall: 3594
Visitors: 95
Total: 95
01: My Account
04: Pictures
07: Links
15: My Account
19: Event Calendar
55: Event Calendar
74: My Account
79: Event Calendar
80: Event Calendar
95: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Max angle for rear axles
Wattsd
Wattsd
Post Post subject: Max angle for rear axles
Posted: Sat Jan 23, 2016 04:40 AM
Just picked up this new toy. What is the max angle for type 1 axles? The PO did not know anything about this little Baja. It has a external cooler and filter with full flow oil system. When I change the oil how much is a good starting point for how much to add I don't want to over service it.
Here's a pic of my new toy. It sits 17 1/2 " off the ground measured under the door.
Thanks for any help.
TINMAN
TINMAN
Post Post subject: Re: Max angle for rear axles
Posted: Sat Jan 23, 2016 09:57 PM
welcome to the site .12 degrees is the max for a type 1 cv
TRUMP 2020
Posted: Mon Jan 25, 2016 03:25 PM
I run them until they start "clicking" then I take them apart and clearance them ... Good to Go.
Posted: Wed Jan 27, 2016 04:26 AM
Nice, and again welcome to the site.
Posted: Wed Jan 27, 2016 03:53 PM
you will need to clearance all your CV's.... even if they are Bus, bug, type 1,2,3,4... if you don't they will over heat and weaken the CV making them prone to break under load. if you can find under sized balls it will save you a lot of work.
if your CV is tight in its travel it will over heat when you drive and dry up the grease after that the CV will supper over heat and blow. I have seen them over heat to the point that it dries up the grease in the bearings. take them apart and clean them up ... I use a flapper wheel that is about the same size as the balls. when the CV is very sloppy in its travel you are done.
Wattsd
Wattsd
Posted: Fri Jan 29, 2016 05:03 AM
Someone has cut the flare off of all the carb stacks. Is there any reason they would have done this? Car seems to be running rich. It still has mechanical fuel pump with no pressure regulator. Do you guys recommend putting a pressure regulator and possible electric fuel pump? Where would be the best location to install these?
Thanks for all the help so far. My CV's are at 13 degrees right now, it has adjustable swing arms so I may have to let it down a little. Not sure about clearanceing the CV. Never had one apart. Any pics of this being done?
Here is a pic of the carb.
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2539 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 3098 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4421 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
irs,swingaxle
3 desertbaja 3361 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
No new posts VW Volkswagen & Baja Bug General Discussion another rear axle question 3 onthefarm 2942 another rear axle ques...
 Sat Aug 04, 2012 05:22 AM
onthefarm View latest post
