Latest: bawward
Overall: 3614
Visitors: 171
Total: 171
08: Event Calendar
15: Event Calendar
16: Event Calendar
22: Event Calendar
51: Event Calendar
82: Event Calendar
84: Event Calendar
91: Event Calendar
92: My Account
94: Event Calendar
107: Event Calendar
120: Pictures
122: Event Calendar
124: My Account
157: Baja Forums
162: Event Calendar
170: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- $%!@# oil leak!
$%!@# oil leak!
ghs215
ghs215
Post Post subject: $%!@# oil leak!
Posted: Tue Jan 12, 2016 03:36 AM
Hi all...
'66 Baja 1600cc DP
During the last river run, I ran out of oil on the freeway while going back home. Dummy light started blinking....pulled over and refilled ~2qts. I checked the oil before I left phx in the morning and it was full, so in about 5 hours, ran it dry. Smacks forehead for not checking it more often.
I thought it was leaking around the oil pump, so I pulled it and made it all new again. But then it started leaking again! Argh, a nice steady leak. I could see (think) that it was coming out somewhere between the pully seal and top of oil pump, right on the case half.
So I tightened up the case nuts, about 1/2 turn. Still leaking....
With other maintenance, I changed the plugs, but also did a compression check...not good results. 60, 30, 30, 30....How the hell is this thing still running?!?!
I imagine I did some damage. Oil filter was clean, no shavings. Engine seems like it has no low end torque, high end OK. Notice some smoke coming out of #4 upon spool down.
So what should i do? Full rebuild, buy/swap a rebuild ("dreaming" put a Subaru in Wink ) Suggestions for getting a rebuilt, where to look?
Thx for listening to my ramble...
-Steve
azdesertrat87
azdesertrat87
Posted: Tue Jan 12, 2016 04:52 PM
there are other people on the forum that have actually put a Subaru in their car and turned out quite nicely. I'm sure that they will chime in on the subject. As for your car I'm guessing that with such low compression that it had a bunch of blow by and on a Volkswagen there is no seal on a stock VW pulley just a reverse thread to pull the oil back in the engine and any thing else on, or around the pulley! If your blow by was great enpugh that it was just blowing all your oil out of the engine! Bummer to hear about it but you can't kill a A/C VW lol! Good luck on wich ever route you choose!
Posted: Wed Jan 13, 2016 04:32 AM
you are right Kenny!!! now I remember.... I had a low compression motor.. and the blow by was pushing the oil out everywhere.. I know this will sound dumb ... but I got by.... by putting a rag in the oil filler and took the cap off to vent the blow by.. after the rag got oil soaked it would stay in the hole.. I ran it that way for a long time. to get oil pressure I had to keep adding gear box oil to the oil to thicken it up in the summer month. that block became my 2180cc turbo motor. who knew it had never been rebuilt... I went thru
2 other "Good blocks" and the one I cared the least about was the best one.
Thanks for the flash back..!!!
azdesertrat87
azdesertrat87
Posted: Thu Jan 14, 2016 03:50 AM
Crazy but it worked! I too have used gear oil to get some oil pressure on some of my vehicals (when I was younger lol!). After I moved down here I discovered motor honey from STP. I remember one time when I first started going on runs with you guys, I crossed a river and the pulley sucked up a whole bunch of water! I didn't carry enough oil for a oil change! I believe it was either Paul or Tom told me to take off my oil filler cap and drive it easy. OMG the steam coming out looked like an old steam train, but by the time we arrived at camp there was no more steam and I swear to you the oil was amber once again! I bet every body here has a get by story or two!
Posted: Thu Jan 14, 2016 03:56 PM
Kenny
I was there that time... we had a few blocks fill up with water .. we just pull the plug until we start to see oil and plug it up and run it until we burned off the water... its called a "motor flush" shops charge for this ..
The scam..
show the customer all that gunk in the motor. tell them for $78.62 you can flush there motor .
Put a few cups of water in the oil. let the oil and water mix to this white goop. the white goop steams loose all the grime in the motor and traps it in the oil filter. when it stops steeming .. the oil looks new again. Change the oil filter.
you are done.
Posted: Thu Jan 14, 2016 03:59 PM
what destroys the motor is rush. don't let it rust.
azdesertrat87
azdesertrat87
Posted: Thu Jan 14, 2016 05:00 PM
Defenatly! also Change that oil! stock vw has no oil filter, just a screen and only holds about 2 1/2 quarts.
No new posts VW Volkswagen & Baja Bug General Discussion The "Where does your VW leak from" thread!
20 Baja_Blue 10966 Re: The "Where does yo...
 Mon Feb 22, 2010 05:11 PM
Baja_Blue View latest post
No new posts VW Volkswagen & Baja Bug General Discussion main fuel line leak... 6 Kev_n_AZ 4284 Re: main fuel line lea...
 Fri Dec 05, 2008 04:25 PM
Kev_n_AZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Oil Leak 1 GeneFrenkle 1674 Re: Oil Leak
 Sat Apr 07, 2007 01:56 AM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion exhaust leak and detonating 4 rayhart15 2992 Re: exhaust leak and d...
 Tue Jan 02, 2007 06:22 PM
rayhart15 View latest post
