Visitors: 271
Total: 271
05: My Account
07: My Account
18: My Account
19: My Account
22: My Account
38: Home
39: Home
61: Event Calendar
74: Pictures
80: My Account
92: My Account
93: My Account
94: Event Calendar
96: My Account
99: Event Calendar
113: Pictures
115: My Account
116: My Account
117: Event Calendar
118: My Account
119: My Account
136: Event Calendar
150: Baja Forums
152: Event Calendar
158: Event Calendar
173: Contact Admin
179: Baja Forums
180: Home
181: Baja Forums
183: Baja Forums
184: Baja Forums
187: Baja Forums
188: Home
190: AMAZON.com
191: Baja Forums
193: Baja Forums
195: Baja Forums
197: AMAZON.com
198: AMAZON.com
201: Baja Forums
202: AMAZON.com
204: Baja Forums
205: Baja Forums
207: AMAZON.com
208: Baja Forums
209: AMAZON.com
210: AMAZON.com
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
216: My Account
217: My Account
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: My Account
222: My Account
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
228: Pictures
229: Baja Forums
230: AMAZON.com
231: Baja Forums
232: Baja Forums
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: My Account
239: AMAZON.com
240: Baja Forums
241: Event Calendar
242: AMAZON.com
243: AMAZON.com
244: My Account
245: AMAZON.com
246: Event Calendar
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: Baja Forums
254: Baja Forums
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: Baja Forums
259: Home
260: AMAZON.com
261: Baja Forums
262: Baja Forums
263: AMAZON.com
264: AMAZON.com
265: Home
266: AMAZON.com
267: AMAZON.com
268: Baja Forums
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Whatcha workin on?
Whatcha workin on?
Post Post subject: Whatcha workin on?
Posted: Fri Jan 08, 2016 10:55 PM
So what's everyone workin on over this nice rainy winter?
Personally I haven't had time to work on any of the VWs, been to busy trying to keep the daily drivers running.
On a side note I did get a new daily: A 1989 Ford Bronco 2 4wd, 2.9 V6 and only 82500 original miles.
Posted: Sat Jan 09, 2016 04:00 AM
Been driving mine. Had the motor out before New Years to fix the rear main seal. But other than that just driving it. Lots of duning lately that's about it. This rain sucks! Lol
Posted: Sun Jan 10, 2016 03:02 AM
I worked on the rail ... I did the maintenance ... forgot a few thing the first time.... was not happy with the shims on the passenger side hub.. re did them ... NASTY SHIP GREASE.. took a nasty hit to the armor.. not sure if I can get it off to change the oil... Changing the oil is the last thing I can think of that needs to be done.
On the Baja I started stripping it down and tabbing things out before I send everything off to the power coater.
striped down the RV.. everything is ready to go to the power coater. - got most of the stuff for the air horn in last week. Not happy with the front rack I built last year... Had some time over new years campout to sit and think about it... came up with a plain on the last day we were out there packing up to go home.. Put it to paper when I got back... looks good... (I hope) checked the funds... they look good ... we will see what is left over after the power coater gets his cut.. Going to use bed liner as a bra on the RV.. thinking of using Rhino liner Inc. to do the job.. need to get it done before I put the bumper back on or President day weekend. did not think anyone wanted to see the work .. so I have not posted anything.
Post Post subject: Re: Whatcha workin on?
Posted: Sun Jan 10, 2016 11:00 PM
I have the old class 5 car torn apart to repaint a few things. However, this cold rainy weather has slowed my progress.
TINMAN
TINMAN
Posted: Tue Jan 12, 2016 12:20 AM
finished lifting JINX, progress has been a little slow because of the cold. the car is in the backyard, bleed the new brakes some new tires and it will be a driver then I can start on bumpers and skid plates and a complete rewire.
TRUMP 2020
vwboat
vwboat
Posted: Tue Jan 12, 2016 03:51 PM
Hi all,
Sorry i missed the last couple of events, Life just gets in the way sometime.
Car is running good for what it is. Been running up to Wickenburg via the Castle hot springs road then taking the Buckhorn rd around Buckhorn mnt into town. kind of an easy fun ride just to get some dirt time.
Hope to see you in the dirt.
VWBOAT(JOHN)
Posted: Wed Jan 13, 2016 03:10 AM
back at you... "Hope to see you in the dirt"
Posted: Tue Jan 19, 2016 07:06 AM
Just installed new new spark plugs, a new belt, changed the oil, installed a new oil pressure switch and also found out that half the bolts were missing from the steering. I'll get new bolts tomorrow and hopefully it won't end up that the threads are stripped.
Posted: Wed Jan 27, 2016 03:23 AM
working on the House, Trim etc. painting and floors next. It is almost done. Been working on my Pinball machines too. Will get to the Baja soon.
Azdrtdog
Azdrtdog
Posted: Wed Jan 27, 2016 02:48 PM
Replaced my single brake master with a dual setup that has the bias on the pedals instead of the inline setup I had, single master was sucking air and I would loose all my pedal half way through a ride and be using the turn brakes to limp home. I also changed the front shocks from 2.5x12" foa to a 2"x10" fox that required me to cut the shock hoops off and shorten everything up, went out behind pleasant last weekend to test run. Little tuning on shocks and some smaller bore masters that can actually stop the car and I should be good
