Latest: Curtis
Overall: 3613
Visitors: 113
Total: 113
16: Event Calendar
43: Home
63: Event Calendar
85: Event Calendar
91: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- Transaxle Bolts stripped
LittleBaja
LittleBaja
Post Post subject: Transaxle Bolts stripped
Posted: Thu Nov 26, 2015 08:51 PM
Messed up big time this morning I accidentally stripped one of the two big bolt hole that the trans-axle mount to. Any ideas on how i can fix this? Don't know the size of the bolts and am having trouble trying to figure out if i should buy a threader tool or what. Any help would be greatly extremely appreciated.
Posted: Sat Nov 28, 2015 06:37 PM
buy a bigger tap and tap out each side... bring the old bolt to the tool shop so they can tell you what is the next size up is. I would go with a standard thread type .... Or weld a bolt into the hole and use a nut to attach the mount.
azdesertrat87
azdesertrat87
Posted: Mon Nov 30, 2015 02:13 AM
I think it's a 18 x 1.25 a heli coil will set you back around sixty bones! you might be able to tow it to a vw garage/ machine shop and they'll do it for you. Daltons Idea would be the easest though, good lusk and please let us know how it turned out!
LittleBaja
LittleBaja
Post Post subject: Re: Transaxle Bolts stripped
Posted: Tue Dec 01, 2015 02:43 PM
Thanks for the help guys am gonna just weld a bolt into both hole and mount it using a nut. Should work, and ought to be easier than tapping a new one out etc.
LittleBaja
LittleBaja
LittleBaja
LittleBaja
Posted: Tue Dec 01, 2015 02:44 PM
LittleBaja
LittleBaja
Broncoboy519
Broncoboy519
Posted: Tue Dec 01, 2015 05:38 PM
Im new I dont know what to do
BajaLife
No new posts VW Volkswagen & Baja Bug General Discussion What size are fender bolts? 2 az350x 3137 Re: What size are fend...
 Thu Dec 02, 2010 11:30 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion CHECK YOUR PIVOT BOLTS!!! 2 BugZyla.com 3255 CHECK YOUR PIVOT BOLTS...
 Thu Sep 09, 2010 10:38 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Marks nuts and bolts on westside-- 3 Brettucks 2950 Marks nuts and bolts o...
 Sat Jan 30, 2010 06:18 AM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion frame horn bolts 2 Colesifer68 2338 frame horn bolts
 Mon Jan 11, 2010 10:22 PM
Colesifer68 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 58 bus transaxle in baja - ? 11 bugaru 18714 Re: 58 bus transaxle i...
 Thu Nov 27, 2008 04:38 PM
