Visitors: 108
Total: 108
04: My Account
24: Event Calendar
86: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Oil Filter or Not to Oil Filter
Do you use a oil filter?
Yes
100% 100% 100%
 100%  [ 3 ]
No
0% 0% 0%
 0%  [ 0 ]
Total Votes : 3
ghs215
ghs215
Post Post subject: Oil Filter or Not to Oil Filter
Posted: Tue Nov 10, 2015 10:29 PM
1966 VW Baja 1600cc
Is it REALLY beneficial to add an oil filter to a stock 1600 engine?
I have an aftermarket motorcycle filter assembly on the pan, but I hate that thing since it is a huge target for a rock. Full flow is an option, but is it really beneficial with the tolerances and thick oil used in these engines? Always BLACK!
Has anyone ever had these full flow filter assemblies fail (oil hose, filter, ect)? Trying to decide the trade-offs.
Any experiences and information welcome. I love learning all I can from those that have experienced failure and what was done to reduce the risk.
Posted: Wed Nov 11, 2015 03:21 AM
starting and high idle in cold weather will blow up a oil filter, lines ECT. the stock VW mtr will not buy pass thick cold oil.
if you run a ext filter your motor will last longer.
if you keep the oil under 180 deg. it will last longer.
with a stock 1600cc I could get 3-4years out of it in AZ.
same block ... full flowed with the dog house + Ext oil cooler, and filter. the oil never got over 180 deg.
was still running strong after 13 years... I turned it into a 2110cc ran it hard for 1 year, turbo-ed for 2years then I sold it to a guy with a 71 bus that wanted to do 80mph all day long.
I was told that you don't need to run a real oil filter because of the mechanical lifters.. if you put in hydraulic lifters you will need to run a better oil filter.
azdesertrat87
azdesertrat87
Posted: Wed Nov 11, 2015 04:06 PM
Agreed with Dalton. They say that the oil pump filters are junk! Has too much resistance in the pump/filter body. I always recommend a full flow set up, unfortanitly the case has to be dissesembled to do it properly. Go to Gene Berg.com a lot of good reading. good luck and look foward to seeing you out on the trails!
ghs215
ghs215
Posted: Fri Nov 13, 2015 01:02 AM
Thank you for the info Dalton and azdesertrat87. Very interesting what Gene Berg has to say (no BS) on every topic.
If you were at the river run, I was the new guy (Steve) in the white baja with my bother-in-law (Tony).
The run was great, but had some trouble on the drive back Sad I think I blew a gasket on the oil pump and lost all oil on the freeway. Filled her back up, but i think some damage was done. Will investigate more this weekend...
azdesertrat87
azdesertrat87
Posted: Fri Nov 13, 2015 02:46 AM
oh ya glad you had fun, there a great bunch of people, look foward to seeing you out on the trails!
No new posts VW Volkswagen & Baja Bug General Discussion Remote Oil Filter
Where is the best location?
4 Adub 2822 Remote Oil Filter
 Wed Feb 15, 2017 09:31 PM
Adub View latest post
No new posts New Members Air filter issues
Can't keep the Dust out
11 DerekT 4984 Re: Air filter issues
 Mon Oct 03, 2016 01:59 PM
No new posts VW Volkswagen & Baja Bug General Discussion Replacing air filter
Breather tube?
3 pschneider 3783 Re: Replacing air filt...
 Sun Jun 13, 2010 04:03 PM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion HELP I NEED OIL FILTER MOUNT 10 bajawarrior 4274 Re: HELP I NEED OIL FI...
 Wed Aug 08, 2007 06:04 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion move air filter inside of car? 10 randode 6524 Re: move air filter in...
 Fri Dec 15, 2006 01:48 AM
