Latest: kevinbaja68
Overall: 3591
Visitors: 86
Total: 86
50: Event Calendar
81: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Sand Sprite II- Total Rebuild
madmax
madmax
Post Post subject: Sand Sprite II- Total Rebuild
Posted: Mon Oct 19, 2015 04:52 AM
Going to make a kind of digital blog on an actual buggy website for my little Sand Sprite rebuild.
Here is how my pops and I picked it up:
We were stoked on the turbo V6 and mid engine layout, and it absolutely SCREAMED down the road. We took it home the next day.
Come to find out that this thing was a just a slapped together basket case... If the person who built this buggy is on this forum, I have a few questions for you!!
A VG30ET Nissan engine is not a good choice if you are looking for something very simple and reliable. Fast as hell, but I am looking for ease of maintenance, simplicity, and ease of getting parts.
Here is how the Sprite sits today in my garage:
Traded the Nissan for a 1915 VW just this afternoon. Since the layout is opposite of how everything was from the factory, I'll have to do some chopping of the sub frame in the rear to be able to get this engine to mount to the trans properly.
That's really all for now but I'll keep this updated as I make progress.
"Enjoy the journey, and you won't lose." -Ivan "Ironman" Stewart
Posted: Tue Oct 20, 2015 12:08 PM
Looks like a great project. Looking to see more photos on your project.
madmax
madmax
Posted: Tue Oct 20, 2015 04:12 PM
Thanks, I'll try to get some more pics of the engine and car tonight while i'm in the garage.
madmax
madmax
Post Post subject: Re: Sand Sprite II- Total Rebuild
Posted: Wed Oct 21, 2015 08:38 PM
Got the 1915 home and started trying to get it into place last night to see how much work was ahead of me. Had to cut a bunch of junk off the sub frame to see if it would even drop into place in front of the transaxle:
I want to punch whoever built this car. How could you think this was good/decent fab work? (old engine mount)
Dropping in
Almost fits...
Nope! Hits the sub frame.
So it didn't fit. I knew it wouldn't though, in my heart of hearts. I tore down the rear suspension on the passenger side to start the process of taking the stock VW sub frame off.
Note the random holes drilled in the frame here; This is standard throughout the car. I'm worried there are so many it may actually affect the rigidity and safety of the chassis.
After all of this, I'm looking at the work in front of me, along with budget and time... Might be at the point of cutting losses, picking the good parts off of this frame and scrapping the rest. The frame itself is built well enough, but the tubing it is made out of is questionable. The soundness of the frame may be compromised due to the massive amount of holes drilled in it, not to mention the crap welded to it.
I figure I have two options:
Option 1: Remove usable parts from frame and scrap it; Take initial purchase price (minus trailer) as a loss and find a more put together project later.
Option 2: Continue dumping money and time into something I have little time and even less money for that may never be finished.
Any advice here from people who have been in similar situations is appreciated!!
TINMAN
TINMAN
Posted: Thu Oct 22, 2015 01:46 AM
The chassis is probably .095 mild steel fine for this type of car weld the holes up and hit them with a flapper wheel. the welds I can see on the chassis look good find a uncut rear torsion and switch it back to rear eng. add a few gussets and go .
TRUMP 2020
madmax
madmax
Posted: Thu Oct 22, 2015 02:10 AM
Tinman, thanks for the advice. I was thinking about just turning it around, but then my transaxle would be turning the opposite way. How do I reverse it? Also, the CVs would then be a good measure farther forward... This creates more issues.
Azdrtdog
Azdrtdog
Posted: Thu Oct 22, 2015 03:14 AM
The ring gear will need flipped, not yor average guy type of thing. Unless the arms have been F'd with the new torsion housing will line it all up in relation to the cv's. Might be a good idea if yor building a trail car and don't want to hear the motor right behind yor seat for hours on end. You will have a ton of time either way, swapping parts or just fixing this one, I would replace the housing if the front half of the car was solid
madmax
madmax
Posted: Thu Oct 22, 2015 03:52 AM
Just went in the garage and measured... Looks like the subframe horns (or whatever) have been cut down, so the trans mounts will not line up like the factory intended them to. Flipping it around is out.
From here, I think plan two (continue dumping money) is the way we're headed.
Azdrtdog
Azdrtdog
Posted: Thu Oct 22, 2015 10:04 PM
That won't be an issue, cut yor housing out then square in a new one. Sleeve and extend the existing horns and run diagonals from frame down to horn between cv and bell housing,cap it with the trans mount at the end and tie the rear cage back in bada boom bada bing can be accomplished in a weekend if you stay at it. And the last stock housing irs swap we did had factory horns still
madmax
madmax
Posted: Thu Oct 22, 2015 11:16 PM
So I have to find a new rear subframe, install it, get the trans rebuilt to spin the other way, and then continue rebuilding the whole car... Or, build a tube sub frame, and mount everything off of that. Option B seems easier here.
Azdrtdog
Azdrtdog
Posted: Fri Oct 23, 2015 02:39 AM
It all about the journey
Posted: Sat Nov 21, 2015 08:27 PM
The frame was originally intended to be mid-engine swingaxle sand dune with coilover or air rear shocks. The torsion housing was added by a previous owner and that is the base source of your troubles.
It may also be that it has 3x3 arms which might be why you perceive that the engine and trans location is not right. Can you post pics of the yokes where you feel they were cut down?
You COULD keep the current torsion housing, cut off the yokes and weld on a pair of Acme (formerly Berrien Buggy) fabricated tube yokes to convert it to rear engine.
BerrienTubularFrameHorns
You could maybe trade your mid-engine trans for a rear engine trans. Your shift linkage will probably need to be revised, But that should be cheap off-the shelf type stuff or from a junked buggy or one that somebody has upgraded their shifter to a fancy one.
madmax
madmax
Posted: Mon Aug 01, 2016 10:10 PM
Still don't know what to do here...
Thinking I should revise everything to run some kind of Ecotec or Chevy V6, but that always ads complexity... I'll keep everyone updated when I get it down to the shop and out of the backyard!
5 bajabuggy69 4914 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Stuck in the SAND (again) 3 vwboat 1862 Re: Stuck in the SAND ...
 Tue Oct 29, 2013 11:36 PM
No new posts Projects and Builds Project Tamiya Sand Scorcher, from Argentina!!!!!!!
59 jadb 46768 Project Tamiya Sand Sc...
 Tue Sep 03, 2013 01:46 AM
Mongoose1983 View latest post
[ Go to pageGo to page: 1 ... 6, 7, 8 ]
108 64sandscorcher 142549 Re: Project Tamiya San...
 Mon Sep 26, 2011 05:04 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need a rebuild on my link pin beam 2 wideopenmotorsports 2886 Re: Need a rebuild on ...
 Wed May 18, 2011 01:38 AM
