Visitors: 97
Total: 97
41: Event Calendar
45: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Brake Drum 4 to 5
Brake Drum 4 to 5
LittleBaja
LittleBaja
Post Post subject: Brake Drum 4 to 5
Posted: Sun Sep 27, 2015 07:21 PM
Hey, I have a 1966 Baja Bug I am working on, I bought a 1975 super beetle for its rear end and now have the problem that I want to have 5 Lug drums all the way around. The 66's drums are not compatible with the 75. I would prefer not to use an adapter plate to go from 4 to 5 lug. Anyone know of a place to buy 5 lug brake drums for the 1975 rear end? Or any other ideas on what I could do. Thanks guys.
Posted: Sun Sep 27, 2015 09:07 PM
VW Thing drums. I think 1969 - 1975
your 66 drums will work.. I cant remember how I did it??? I think I moved the backing plate from the 66 to the IRS... I think I needed to use a spacer to get the 36mm nut tight.
LittleBaja
LittleBaja
Post Post subject: Re: Brake Drum 4 to 5
Posted: Tue Sep 29, 2015 04:00 PM
Thanks bud I will have to give this a try then, definitely will save a little money on my project!!
TINMAN
TINMAN
Posted: Tue Sep 29, 2015 06:08 PM
axle nut spacers are available at a bunch of shops for about 15 bucks thing drums are 100 ea.
TRUMP 2020
1 LittleBaja 2288 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3138 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
24 vwboat 10951 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
what are yall's set'ups
7 vindeta 14347 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
No new posts VW Volkswagen & Baja Bug General Discussion pedal assembly brake thing 9 jone$yyy 3101 pedal assembly brake t...
 Sun May 02, 2010 06:27 AM
jone$yyy View latest post
