Latest: Curtis
Overall: 3613
Visitors: 112
Total: 112
24: My Account
38: Event Calendar
41: Home
55: Event Calendar
60: Event Calendar
81: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Brake Drum 4 to 5
Brake Drum 4 to 5
LittleBaja
LittleBaja
Post Post subject: Brake Drum 4 to 5
Posted: Sun Sep 27, 2015 07:21 PM
Hey, I have a 1966 Baja Bug I am working on, I bought a 1975 super beetle for its rear end and now have the problem that I want to have 5 Lug drums all the way around. The 66's drums are not compatible with the 75. I would prefer not to use an adapter plate to go from 4 to 5 lug. Anyone know of a place to buy 5 lug brake drums for the 1975 rear end? Or any other ideas on what I could do. Thanks guys.
Post Post subject: Re: Brake Drum 4 to 5
Posted: Sat Oct 03, 2015 04:52 AM
You can use the 66 drums. but you will need a spacer between the drum and the nut. For a direct bolt on, 73/74 Thing drums are wide 5 and a direct bolt on.
3 LittleBaja 2942 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3954 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
24 vwboat 13647 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
what are yall's set'ups
7 vindeta 16917 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
No new posts VW Volkswagen & Baja Bug General Discussion pedal assembly brake thing 9 jone$yyy 3559 pedal assembly brake t...
 Sun May 02, 2010 06:27 AM
jone$yyy View latest post
