Visitors: 114
Total: 114
03: Event Calendar
86: Pictures
87: Event Calendar
113: Event Calendar
My 69 project
1 2 3 ... 49 50 51 ... 78 79 80
Posted: Fri Aug 28, 2015 02:59 AM
here it is again ... laughing at me... Do you see it?
Posted: Fri Aug 28, 2015 03:01 AM
Posted: Fri Aug 28, 2015 03:03 AM
It does kinda look I can propel the car with the fans.
Posted: Sun Aug 30, 2015 11:05 PM
well how many of you guessed the "show stopper " was weather stripping?
I use weather stripping to split the radiator into two sides ... I have lost many fans on the trail due to mud, sticks, Jumping my car.. (remember that one Kenny?? did not see that one coming. I had two fans on the car that day but when the fan exploded it blew a hole in my radiator.. ) poor connector giving up.( on my rail and Baja I run 4 separate wires from fan to inside my car, two 30amp fuses, two relays. to inside my car) now when something goes wrong (and it will) I can still drive the car. if you don't block the two sides you wont get the air you need thrue the radiator.
Posted: Sun Aug 30, 2015 11:11 PM
the other thing I learned over the years is the fewer connections you have the more chance of failure, so I solder everything that is import and something's that are not just so I don't mess with them later.
Posted: Sun Aug 30, 2015 11:12 PM
Posted: Sun Aug 30, 2015 11:16 PM
this part did not work as well as I thought... I needed lines to run the hot water up and down to the motor. I think as myself as a good bender so I thought if I bent up some lines and they looked good I would save a lot of money...
Posted: Sun Aug 30, 2015 11:17 PM
Posted: Sun Aug 30, 2015 11:21 PM
I am way not happy.... but it was cheep... the other side was done in about an hour.
Posted: Sun Aug 30, 2015 11:24 PM
took it out .... ran it about 75mph to 80ish...
I think the problem is solved never got over 200 deg.
the fans come on at 212 deg. so that means that there is enough air flow that the fans don't need to come on... YEA!!!
Azdrtdog
Azdrtdog
Posted: Sun Aug 30, 2015 11:30 PM
Good deal, if you get a gates 21620 for yor top hose is has a 120degree bend you can cut out and get rid of the shepherds crook one run that pipe straight down and facing back
Posted: Wed Sep 09, 2015 03:03 AM
another awesome trip to flagstaff... went out and played with some jeepers... bad idea,, they had lockers and I did not notice it until it was too late... got some new dents in the armor... bent a shock,,, blew a tire off the rim... and something is not right in the front end??? I know I bent something. But I made it out alive... and under my own power... it took ever bit of driving to get out alive after they set the hook. I would have felt better if I was in the rail.. but I think I would took some damage.
I will check the car out a later this week..
F.Y.I. radiator creep solved..
Posted: Thu Sep 24, 2015 01:22 AM
well went thrue the front end,, damage report: bent shock, New leak in power steering(not bad)... I forgot to tighten a bolt on my tie rod and caused it to come loose. working on cleaning up the new plumbing it starting to look good. I hope to have it ready for Crown King.
Posted: Sun Sep 27, 2015 03:23 PM
Posted: Sun Sep 27, 2015 03:24 PM
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3602 Project Purple People ...
88 Dirtjunkie 63750 Project II
65 PaDan 57949 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8529 Re: new project
38 NoKnowledgeCollegKid 22192 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
