Latest: slyster
Overall: 3568
Visitors: 142
Total: 142
14: Pictures
43: Pictures
82: Home
85: Event Calendar
86: Pictures
103: Event Calendar
128: Event Calendar
136: Pictures
My 69 project
1 2 3 ... 45 46 47 ... 77 78 79
Posted: Wed Aug 12, 2015 12:58 AM
Posted: Wed Aug 12, 2015 01:00 AM
Posted: Wed Aug 12, 2015 01:01 AM
Posted: Wed Aug 12, 2015 01:02 AM
looks like that will work...
azdesertrat87
azdesertrat87
Posted: Wed Aug 12, 2015 05:12 PM
a sealed fan sroud will really move all the air through the radiator thats really going to help keep it cool!
Azdrtdog
Azdrtdog
Posted: Wed Aug 12, 2015 07:16 PM
Also keeps those pesky mud clods out so you don't burn up yor fan motor, recently was witness to that. I also found that removing the T stat helped keep mine from getting hot under long loads, if I ran 75 down the highway it would creep up to 240 but after I gutted the therm and just used it as a restricter it runs 190 all day and the fan keeps it in check
azdesertrat87
azdesertrat87
Posted: Wed Aug 12, 2015 08:32 PM
I guess antifreeze disapates heat faster than it picks it up. a restrictor helps slow down the flow of antifreeze through your engine so it can pick up the engines heat. I just need to find some water to play in lol!
Azdrtdog
Azdrtdog
Posted: Wed Aug 12, 2015 08:42 PM
kinda, stupid suby' have the T stat on the inlet and the cool water from radiator closes the dam thing till the engine circulates enough heat to open it again, I chased this problem for over a month till I took Outfront racing advice and ditched it. even with the recirculating hose allowing the water to move in block it was a issue. The biggest tell tale was my motor was 240 and my radiator was cool enough to touch with yor bare hand
Posted: Thu Aug 13, 2015 02:54 AM
Removed the T stat and it did not help. I use the OEM recirculating system it helped a lot.
Posted: Thu Aug 13, 2015 02:57 AM
tried ducks..
Posted: Thu Aug 13, 2015 02:59 AM
tried the fan on the other side...
Posted: Thu Aug 13, 2015 03:01 AM
all helped ,,, but none were the cure.
Now it is time to bite the bullet and just move the radiator into the air flow.
Posted: Thu Aug 13, 2015 03:04 AM
I got the cooling system working up to about 100 deg. after that I get radiator creep.
Posted: Thu Aug 13, 2015 03:05 AM
I only have 3mo. to test the new systems a year so I better get on it.
Azdrtdog
Azdrtdog
Posted: Thu Aug 13, 2015 03:56 AM
That's crazy, you have twice the radiator I have. Mine is off a john Deere mower that had a 3cyl diesel, I tried drilling holes like you did but then I cut the tower out of my T stat and just used the circle as a restrictor and gasket to seal the neck. My temp sender is on the crossover in stock location and for now I still have the recirc hose running from the left side of block back to the therm housing but I'm going to ditch that since I have a free flowing system. My heat issue was all circulation related, have you double check water temp as it leaves radiator? The whole time I was fighting this same issue I could hold the lower tank in my hand and that told me rad was doing its job. Right now I have a single puller fan and I can run 3500rpms all day in 115 degree heat or leave it idling for hours with no issues
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1158 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 48367 Project II
65 PaDan 46562 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6389 Re: new project
38 NoKnowledgeCollegKid 15803 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
