Latest: BlackIrish05009
Overall: 3574
Visitors: 129
Total: 129
08: Event Calendar
11: Event Calendar
22: Event Calendar
24: My Account
44: Pictures
48: Event Calendar
60: Event Calendar
68: Event Calendar
71: Event Calendar
74: Event Calendar
96: Event Calendar
102: Event Calendar
109: Event Calendar
120: Event Calendar
124: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- CLASS 5 Resurrection!
Post Post subject: CLASS 5 Resurrection!
Posted: Sun Oct 05, 2014 11:19 PM
Is that power steering I see or a dry sump system?
Post Post subject: Re: CLASS 5 Resurrection!
Posted: Mon Oct 06, 2014 02:04 AM
Power steering
Posted: Mon Dec 29, 2014 02:52 AM
Starting from the back and working forward. Lots of stuff to do. Process will take some time.
Needed a new jack and had to make an extension. Took square tubing and made a 13" extension to jack up the car enough to get the tires off the ground.
Dropped the rear cage and started working on the rest of the tubing in order to paint it. From the back to the front will be the process here.
Posted: Sun Jan 18, 2015 11:23 AM
I do like the jack. I need somthing like that.
Posted: Sun May 31, 2015 03:38 PM
Had time Saturday so I started back on the 5 car. Old, bulky race fuel cell is now gone. Need to build some brackets to hold a new fuel cell and a shelf for oil and misc parts. Some left over angle iron, welder and some time was all I needed.
Start with some brackets.
Time for the shelf.
Will double check the fit on Sunday.
Posted: Sun May 31, 2015 07:43 PM
Time to see how everything fits together.
Everything went together great. Wrap the parts up, put them to the side and move onto the next project.
Next step is to build a firewall to protect the passengers.
Posted: Mon Jun 01, 2015 02:13 AM
Spent the day welding tears in the parcel tray and replacing body bolts that decided to fall out. Inside is completely clean and stripped. Now I can sand the cage, add a fresh coat of black and then repaint the interior.
Posted: Mon Jun 08, 2015 11:28 PM
Worked all weekend on the car. It seems like the more I work on it the more I have to do. So I made progress this weekend, it just seems like I didn't.
Maybe I will have some updated pics next weekend.
Posted: Sat Jun 27, 2015 09:11 PM
Time to repaint the entire cage and interior of the car. Gonna take a few weekends, but so far the dark grey hammer tone paint looks good.
vwboat
vwboat
Posted: Sun Jun 28, 2015 08:51 PM
Tony,
Looking good.
VWBOAT(JOHN)
Posted: Mon Jul 06, 2015 03:49 AM
Spent the past three days sanding, painting, taping areas off, sanding and painting more. The cage and interior is done. A few days to dry and then I can start to assemble the interior.
Posted: Fri Jul 10, 2015 05:24 AM
You have that touch! Good job Tony!
Posted: Mon Jul 13, 2015 01:38 AM
OK, so I have the cage painted and now I have to tape off the newly painted cage to paint the interior.
I'm doing a three stage grey / speckle tone / clear for the interior. I have found it looks good and hides a lot of imperfections in the metal. A WIN / WIN in my opinion.
FINALLY DONE! Can start working on some wiring and getting the new dash installed.
Last edited by wideopenmotorsports on Mon Jul 13, 2015 02:25 AM; edited 1 times in total
Posted: Mon Jul 13, 2015 01:56 PM
You must have saved newspapers for months to get that number of papers! Looks great!
Posted: Sun Jul 26, 2015 08:00 PM
Well got a few hours in yesterday on the car. All new lines for the power steering and a little wiring work.
Also got the rear firewall and wheel wells painted. Back at it again today. Need to prep and paint the underside of the rear fenders to match.
Last edited by wideopenmotorsports on Sun Jul 26, 2015 08:01 PM; edited 1 times in total
25 Kreed 23093 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 4375 New Class 11 Build - P...
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 2909 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 5007 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
No new posts Projects and Builds class 5 baja bug needs motor... 0 Azbugracing1214 2474 class 5 baja bug needs...
 Tue Jun 09, 2015 12:51 AM
