Visitors: 140
Total: 140
13: Event Calendar
39: Home
40: Home
78: Pictures
82: Event Calendar
95: Event Calendar
114: Links
123: Event Calendar
125: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- New to VW and the Baja Bug
303visual
303visual
Post Post subject: New to VW and the Baja Bug
Posted: Mon May 11, 2015 04:55 AM
Hello everyone,
I just bought a 1973 baja bug. Ill start by saying i am very new to vw and while I've done a fair amount of work on Toyota and Subaru this is a whole new animal. I am not a mechanic but I'm learning. Ill start by listing out what i know i need to do to the vehicle and what i am hoping to accomplish.
I am looking to build a car that is street legal in its most stripped down form. Comfort is not important, looks don't matter. I plan on racing in some capacity but nothing serious. The engine has gotten a good amount of work and seems to run well. Starts right up, but doesn't idle well (stalls out almost immediately after you let off the gas.), thinking im going to need to do some work getting the carb setup but i really haven't dug into it yet.
There are currently not any shock absorbers on the vehicle. I have all shock to put on and mounts seem to be intact.
CV's are in rough shape will at least need to rebuild the upper joints probably just replace both axles.
Shifting is super sloppy but im told this might just take some getting used to.
Brakes suck.(told they work but take some pumping.) Anyone instal disc brakes or have experience upgrading the stock brakes?
plan on adding roll cage, racing seats and harnesses
also plan to strip any unnecessary interior, door panels, insulation headliner, dash ect.
Basically what I'm looking for is any advice for a first time builder. Any information about the topics listed above would be much appreciated. I will post pictures, questions and more information as soon as possible. Is there a dedicated section for documenting a build?
____\r\n / \\--; \r\n````{0)---(0}
5 Admin_AzBaja 6820 Baja Bugs on Wiki need...
1568 mufasavnvmc 1000534 Re: what did you do to...
285 MusicManiac 241644 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 47 FREE VW BAJA'S
0 Northmountainauto 1543 Shop Baja
