Visitors: 135
Total: 135
28: Event Calendar
57: Home
102: Event Calendar
127: Pictures
My 69 project
1 2 3 ... 41 42 43 ... 78 79 80
Posted: Sat Mar 28, 2015 03:27 AM
at this time I have a bank of 6 T-105 that can carry the load thru the night... I am getting set up to see what is left at the end to see how I am doing..
I just finished setting up a system to share my solar with another RV without sharing my battery banks with them.. the extra solar power can charge there battery banks as well as my banks.
I have a smart meter on my house and if I pump my solar into my house the smart meter will know and tell SRP.
there is a lot of safety stuff $$$$$ that must be put in place to put solar on your house. they don't really want the home owner to install the system.. if the solar is not wired correctly it could unknowingly hurt a fire fighter or a line man.
the more I read the more it was about safety than anything else.
some of the solar arrays can kill you easily.. and if it get outside of your house it can kill others.
it seems that the off griders... anything goes...
Posted: Fri Apr 03, 2015 02:21 PM
well I happy with the solar setup on the RV... I moved all the controls to one spot for ez access.
Posted: Fri Apr 03, 2015 02:28 PM
sorry...
top left... battery cut off set to disconnect at 12.0V
top right... solar voltage and amps
second row left... remote on/off for the 120V inverter
second row right... amps into and out of the battery banks
bottom right.. remote control for the solar charger
under that .. Light switch.
most of this I had to build myself to get what I wanted.
Posted: Sat Apr 04, 2015 08:11 PM
Solar.
When thinking about installing a Solar "anything" you need to know that you wont get the max rating on anything... What I read is that solar company's use a "Max standards" system. that means the they use the best possible conditions to rate there systems...
I figure I loose about 1/4 of my system "max rating".. it kinda safe this way.
My solar system is at its best when the sun is high in the sky anything else my solar system is degraded .. all the way to zero at sunset.
Posted: Tue Apr 07, 2015 03:30 PM
got 6 centerlines rims. nothing makes the car look better than some new centerlines!!
Posted: Tue Apr 07, 2015 03:34 PM
2 X 4.5"
2 X 6"
2 X 7.5"
fixed a few small problems with the rail.. did not find anything major. But I still need to perform a bumper to bumper shake down... maybe this weekend.
I am starting to feel the need for a DIRT FIX!
vwboat
vwboat
Posted: Tue Apr 07, 2015 04:39 PM
Lookin good Dalton..
Posted: Mon Apr 27, 2015 02:21 AM
Finally got the Baja back in the shop...
I making a shopping list of what it needs..
I am also making a "need to do list"
the Baja seems to faired much better than I thought after hitting that bolder in Lake Havesu City.. I will know more once I pull the gear box.
Posted: Mon Apr 27, 2015 02:28 AM
Found this really cool speedo .... don't know what it comes out of .. but it looks like it will fit!
old speedo.
New speedo..
Posted: Sun May 03, 2015 03:40 AM
well ... ripped everything apart... Found the only way I can get the seal is to buy a rebuild kit.. so I guess I am going to rebuild the steering box. I was not happy with the way it mounted so I going to add a brace ..
Posted: Sun May 03, 2015 03:41 AM
Posted: Sun May 03, 2015 03:43 AM
what a mess..
Posted: Mon May 04, 2015 12:49 AM
Done.
Posted: Mon May 04, 2015 12:51 AM
took the car for a test run... working AWESOME!!
Posted: Mon May 04, 2015 12:52 AM
Before...
After...
Much nicer....
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3593 Project Purple People ...
88 Dirtjunkie 63675 Project II
65 PaDan 57880 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8524 Re: new project
38 NoKnowledgeCollegKid 22163 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
