Visitors: 107
Total: 107
02: Event Calendar
08: Event Calendar
23: Event Calendar
26: Event Calendar
31: Event Calendar
48: Event Calendar
49: Home
58: Pictures
90: Contact Admin
95: Event Calendar
97: Pictures
106: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- Yellowchev
Yellowchev
yellowchev
yellowchev
Post Post subject: Yellowchev
Posted: Fri Mar 06, 2015 08:16 PM
Hey all,
Found the forum in my search to educate myself on building a baja bug for a rec vehicle. Seems like there is a lot of resources here so I joined. Excited to be a part of the community.
Posted: Fri Mar 06, 2015 10:42 PM
Welcome to the site. Lots of knowledge to be obtained from this group. Everyone knows a little bit about something. Don't hesitate to ask.
yellowchev
yellowchev
Posted: Sun Mar 08, 2015 12:21 AM
Thanks!^^^^
yellowchev
yellowchev
Posted: Wed Mar 11, 2015 04:23 AM
Found this on Craig's. What do you guys think?
bozeman.craigslist.org...47410.html
Good project material?
Any suggestions?
It's got an automatic shifter, rwd, I'm assuming it's got an IRS type 1 transaxle, it does have a ball joint front end, 1600cc engine.
Let's hear what you would consider if this was an option you were entertaining...
Posted: Wed Mar 11, 2015 11:29 PM
I have always stayed away from Autosticks.. Weard.. not sure what it takes to convert it to a 4 speed.
yellowchev
yellowchev
Posted: Thu Mar 12, 2015 01:13 AM
Ya havent learned too much about them but there would definitely need to be a conversion. And I don't know if its worth it or not
vwboat
vwboat
Posted: Thu Mar 12, 2015 05:48 PM
Welcome to the site yellowchev.
VWBOAT(JOHN)
yellowchev
yellowchev
Posted: Thu Mar 12, 2015 11:06 PM
Thanks!
Post Post subject: Re: Yellowchev
Posted: Fri Mar 13, 2015 12:48 AM
as far as I know ...???
the 4sp will fit..
I think the shifter will work.
will need both axles..
may need cluch tube installed.. (this is a pain in the butt)
call Jan... he would know what needs to be done right off the top of his head. 602-243-1238 tell him I sent you.
Posted: Fri Mar 13, 2015 09:24 PM
The autostick trans is not a very reliable unit for offroading. At one time, B&M was modifying them into a pretty good piece, but they didn't sell well and the technology and parts have been lost to time. The center tunnel of the car does not have the clutch cable tube and as said above, it's a PITA to add one.
If you read my post in the college kid's thread, you'll see that I recommend buying a Baja Bug instead of starting from scratch.
yellowchev
yellowchev
Posted: Mon Mar 23, 2015 09:12 PM
Thanks for the help guys... I heeded daltons advice about the auto stick... I also think I would feel guilty with that particular vehicle. It was original chassis and original engine (numbers matched) and auto stick is somewhat rare? So I left it thinking that car has a different purpose.
And Mojave... I got your post and agree with you. I was searching for a baja bug relatively close to home and found nothing so I broadened the search and found that post. But i did find this project:
greatfalls.craigslist....77879.html
I am asking him about the front and rear suspension and the transaxle. Any pointers? My wife is halfway considering this one Smile Let me know if you guys have suggestions as before on specifics to consider. Thanks in advance.
Posted: Mon Mar 23, 2015 10:36 PM
Priced right... swing axle trans, king pin front end... good starter car. Make sure it is not all rotted out.
yellowchev
yellowchev
Posted: Tue Mar 24, 2015 12:02 AM
Sweet!
Posted: Tue Mar 24, 2015 01:03 AM
remember... this is a street car with big tires on it.. if you beat on it, it will break. but great for light off roading.
yellowchev
yellowchev
Posted: Tue Mar 24, 2015 04:03 AM
Right. Main focus is to get it in a comfortable condition mechanically then beef up over time. That's if we pursue it. Still waiting on pictures of interior and pan
