Latest: danmcfly
Overall: 3577
Visitors: 106
Total: 106
12: Event Calendar
22: Home
31: Home
47: Home
73: Home
89: Event Calendar
105: Home
Baja Forums -:- AzBaja.com Members -:- New Members -:- Thinking about a Baja Bug project, need advice.
Post Post subject: Thinking about a Baja Bug project, need advice.
Posted: Sun Mar 08, 2015 04:09 AM
Green stuff -- I hear it happens to the Earth when plants get a lot of water.
Posted: Sun Mar 08, 2015 04:11 AM
Click my link in my photo of my car to see my build.. you might get an idea or two.
I think there is a few other links of other builds out there.
Posted: Sun Mar 08, 2015 04:14 AM
to start buy something running and drivable ... learn as you go.
yellowchev
yellowchev
Posted: Sun Mar 08, 2015 05:53 AM
Dalton you rock! This is good stuff!
NoKnowledgeCollegKid
Post Post subject: Re: Thinking about a Baja Bug project, need advice.
Posted: Sun Mar 08, 2015 05:11 PM
Agreed, thanks Dalton, this has bee super helpful seeing as how like my name says, my knowledge on bugs is practically none.
yellowchev
yellowchev
Posted: Mon Mar 09, 2015 12:43 AM
I'm still trying to understand the transaxle stuff. The .002 and .091 is a ratio? As in 1 revolution of the engine give .002 or .091 revolutions to the axle? If that is true, the .002 is better how? Its lower geared which is better in anything besides pavement?
yellowchev
yellowchev
Posted: Mon Mar 09, 2015 12:48 AM
Also... What is anyone's take on the pricing found in these ads for transaxles?
Just so I have an idea of what to expect when purchasing?
.002
moseslake.craigslist.o...14727.html
.091
portland.craigslist.or...85506.html
yellowchev
yellowchev
Posted: Mon Mar 09, 2015 12:51 AM
Sorry for all the questions. If there is a better, less annoying way to go about this let me know. Thanks in advance.
Posted: Mon Mar 09, 2015 01:54 AM
Dalton, what engine did you swap into your bug though? It looks like you were doing a lot of work for an intercooler, we it turboed? That is something that I'm considering to increase the hp.
Posted: Mon Mar 09, 2015 02:38 PM
did you guys check out this link?
Posted: Mon Mar 09, 2015 02:43 PM
.002 and .091 are the part numbers...
the .002 has low RP so you can run bigger tires with a low HP motor.
Posted: Mon Mar 09, 2015 02:53 PM
.002
.091
the .002 is a good price..
the .091 is a "side shift" even thought the "side shift" is stronger than the .091 "nose shift" it is much harder to install.
a used or core .091 is about $600.00ish... Cores may or may not work. some of the best trans I have owned were cores.
I am not up to speed on the .002 cores I would guess around $400.ish.
yellowchev
yellowchev
Posted: Mon Mar 09, 2015 04:42 PM
Awesome. That is super helpful. And yes I Checked out the link to your project. I for sure will be using that as a reference when I start a project.
Posted: Tue Mar 10, 2015 01:28 AM
it is a Subaru 2.5l quad cam.. "Old school" but it works very well. I didn't want to cut a hole in my firewall. next time I am going to move the trans back 3" then install the motor..
No it is not a Turbo... I am a "Turbo Holic" I just cant keep my foot out of it....
Turbo are way cool-cheep HP.. But I feel they are not meant to be put on a air cooled motor in Airzona... I had a lot of trouble getting it to work well... had a lot of trouble of dissipating the heat.
You cant just slap a Turbo on something and expect it to work..
you must build a "turbo motor and add the appropriate Turbo"
in the end....
I found it cheaper to go with the appropriate sized water cooled Motor for what I was going to use the car for.
it cost just about the same to build a big Air cooled motor as to put in a water pumper.. (I think)
Posted: Tue Mar 10, 2015 02:51 PM
in the end....
That makes sense, I'm from Dallas, TX so would it be worth eventually looking into a water cooled engine? I figure with the heat that we get down there getting over 100 that it might just be too much for an air cooled.
4 Admin_AzBaja 6051 Baja Bugs on Wiki need...
1568 mufasavnvmc 941327 Re: what did you do to...
285 MusicManiac 226883 Re: Baja sightings
1199 Dalton 304149 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 2206 Project Purple People ...
