Visitors: 372
Total: 372
02: Pictures
12: Pictures
15: Event Calendar
16: Event Calendar
18: Event Calendar
19: Event Calendar
20: Event Calendar
22: Event Calendar
23: Event Calendar
26: Event Calendar
27: Event Calendar
28: Event Calendar
54: Event Calendar
55: Event Calendar
71: Event Calendar
72: Event Calendar
73: Event Calendar
74: Event Calendar
75: Event Calendar
76: Event Calendar
79: Pictures
86: Event Calendar
117: Home
124: Event Calendar
128: Event Calendar
137: Event Calendar
138: Event Calendar
139: Event Calendar
150: Baja Forums
151: Event Calendar
164: Baja Forums
168: Baja Forums
169: Event Calendar
170: Baja Forums
171: Event Calendar
172: Event Calendar
173: Event Calendar
174: Event Calendar
176: Event Calendar
177: Event Calendar
181: Event Calendar
182: Event Calendar
190: AMAZON.com
191: Baja Forums
197: AMAZON.com
198: Event Calendar
200: Baja Forums
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: Event Calendar
207: Baja Forums
208: Baja Forums
209: Baja Forums
210: AMAZON.com
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: Event Calendar
230: Baja Forums
231: Baja Forums
232: Baja Forums
233: Baja Forums
234: Event Calendar
235: AMAZON.com
236: Event Calendar
237: Event Calendar
238: AMAZON.com
239: Event Calendar
240: Baja Forums
241: Event Calendar
242: Event Calendar
243: Event Calendar
244: Event Calendar
245: Event Calendar
246: Event Calendar
247: AMAZON.com
248: Event Calendar
249: Event Calendar
250: Event Calendar
251: Event Calendar
252: Event Calendar
253: AMAZON.com
254: Event Calendar
255: Baja Forums
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: AMAZON.com
278: AMAZON.com
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: AMAZON.com
283: AMAZON.com
284: Baja Forums
285: AMAZON.com
286: Baja Forums
287: Baja Forums
288: AMAZON.com
289: AMAZON.com
290: Baja Forums
291: Baja Forums
292: Baja Forums
293: Baja Forums
294: Baja Forums
295: AMAZON.com
296: Home
297: Baja Forums
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: Baja Forums
302: Baja Forums
303: Baja Forums
304: AMAZON.com
305: AMAZON.com
306: AMAZON.com
307: AMAZON.com
308: Baja Forums
309: AMAZON.com
310: Baja Forums
311: Baja Forums
312: Baja Forums
313: Baja Forums
314: AMAZON.com
315: Baja Forums
316: Baja Forums
317: AMAZON.com
318: Baja Forums
319: Event Calendar
320: Event Calendar
321: AMAZON.com
322: AMAZON.com
323: AMAZON.com
324: AMAZON.com
325: AMAZON.com
326: AMAZON.com
327: AMAZON.com
328: AMAZON.com
329: AMAZON.com
330: AMAZON.com
331: Baja Forums
332: AMAZON.com
333: Baja Forums
334: AMAZON.com
335: AMAZON.com
336: AMAZON.com
337: AMAZON.com
338: AMAZON.com
339: AMAZON.com
340: AMAZON.com
341: AMAZON.com
342: AMAZON.com
343: AMAZON.com
344: AMAZON.com
345: AMAZON.com
346: AMAZON.com
347: AMAZON.com
348: AMAZON.com
349: AMAZON.com
350: AMAZON.com
351: AMAZON.com
352: AMAZON.com
353: Event Calendar
354: AMAZON.com
355: AMAZON.com
356: AMAZON.com
357: Baja Forums
358: AMAZON.com
359: AMAZON.com
360: AMAZON.com
361: AMAZON.com
362: AMAZON.com
363: AMAZON.com
364: AMAZON.com
365: AMAZON.com
366: AMAZON.com
367: AMAZON.com
368: AMAZON.com
369: AMAZON.com
370: Baja Forums
371: AMAZON.com
372: AMAZON.com
Baja Forums -:- Off-Road & VW Based Clubs (4x4, ATV, Jeep, Motorcycle) -:- Events and Get Togethers World Wide -:- Hassayampa
Hassayampa
Post Post subject: Hassayampa
Posted: Sun Feb 02, 2014 07:44 PM
John..
I caught up with the group at Patton Rd. the problem was I did not have enough time to properly test all the systems before the run.. I had a few other "look what I forgot to do" along the way but nothing that slowed me down.. I have a few more bugs to work out...
I really like the ride... "for not putting a lot of money into the suspension" its not as fast as the rail but it is comfortable.. with the widen beam the car has a lot less body roll.
We let the rail/Baja open it up a few times .... I could tell they had fun by the dirt in there teeth.
Team Baja was a blast to ride with... we travel about the same speed.. now... I slowed down to enjoy the ride..
went over the car this morning it looks good ... need to be washed...??? (Naaaaaaaa!)
azdesertrat87
azdesertrat87
Posted: Wed Feb 05, 2014 05:08 AM
thanks for the run it was so much fun! Headding up the river I drove off of a 5 foot ledge! I was puckering for an impact that never came, just gently hit the bump stops and Didn't even slow down it was so cool! We stopped in Wickenburg at a place called the Hog Trough Muey exelentae BBQ! Once out of town on the Constelation mine road I noticed the brake pedal starting to go lower and lower untill I had to pump it trice to just slow down,not good on a twisty mountain mine road! on my rail I can either shut off the front or rear brakes, I shut off the rear and I had a normal pedal, then I shut off the fronts and holy cow I had to pump it like crazy. O.K. so now I know the problem is in the rear. next break and I give the rear tires a quick shake and thats when I notice the right rear has a little play. Now I'm slowed down a bunch (front brakes only). By the time we get to the paved road everyone is saying thier goodbyes I was inspecting the right rear tire, I squeezed the cv boot and smoke came out, thats hot! I let it cool a little bit and pulled the boot back and put a tube of cv grease in the cv, slid the boot back and put on a new band, then headed home I took every back road and dark alley fron Lake Pleasant to my home going about 25 to 30 mph slow but it cept the bearing from overheating!
Sunday I got up early dissasebled that side and the inner bearing's rollers were gone as was the seal just the outter ring of the seal nothing! but the outter bearing was just fine, I'm thinking some how I got sand in the inner bearing (cv side)and it just chewed up the bearing. The wild part is that no body has these bearings and races in Phoenix, But Amazon does and a lot more, I'll be ordering them this Sat. I can;t believe I drove over 30 miles with no inner bearing! thanks to everybody that went, need to hussle for presedents day
Posted: Wed Feb 05, 2014 04:32 PM
I have a set of bearings you can use as lone as you replace them.
azdesertrat87
azdesertrat87
Posted: Thu Feb 06, 2014 02:39 AM
oh thanks but Amazon has them gonna order them Friday night! But did you borrow my stub axle and the two bearings I use to set up the end play? I can't find them an am gonna need them to set up the end play. Thanks
Posted: Thu Feb 06, 2014 02:51 AM
no I did not barrow them I just used my axles... you should not need to set up the end play.. it should be the same.
Posted: Mon Feb 10, 2014 03:02 AM
Good time.. good fokes.
Posted: Mon Feb 10, 2014 03:03 AM
John tried to finish but rack issues made him go home.
Posted: Tue Oct 21, 2014 05:04 PM
hey everyone..
I am going to pre run the Hassayampa this Saturday 10/25/2014 @ 8 am. The Hassayampa River run starts at the waffle House at 83rd Ave. and McDowell we leave from there drive up to 339th Ave. Turn right to McDowell Road then we then take McDowell Road to the bottom of the Hassayampa River most non-Street legal vehicles meet us at this point. Then we drive up the Hassayampa River to Wickenburg the non-Street legal vehicles will turn around and go back down the Hassayampa River run while the rest of the vehicles going to Wickenburg for lunch then we take the constellation mine Road over to the Castle Hot Springs Rd. then exiting at the lake pleasant recreation area. This is a very easy run a stock Baja can easily make this event.
See Ya in the dirt!
Posted: Thu Oct 23, 2014 02:35 AM
hey Off-roaders!!!
If you are thinking of going this weekend.... you need to let me know. there maybe a slight change to the Route..
Send me a PM to let me know if you are coming.
Posted: Sun Jan 25, 2015 08:32 PM
Its that time of year again!!!
Posted: Sun Jan 25, 2015 08:34 PM
time to run the Hassampa river run...
this year it will be on January 31st...
Posted: Sun Jan 25, 2015 08:37 PM
The Hassayampa river Run January 31st at leaving at 9 AM. The Hassayampa River run starts at the waffle House at 83rd Ave. and McDowell we leave from there drive up to 339th Ave. Turn right to McDowell Road then we then take McDowell Road to the bottom of the Hassayampa River most non-Street legal vehicles meet us at this point. Then we drive up the Hassayampa River to Wickenburg the non-Street legal vehicles will turn around and go back down the Hassayampa River run while the rest of the vehicles going to Wickenburg for lunch then we take the constellation mine Road over to the Castle Hot Springs Rd. then exiting at the lake pleasant recreation area. This is a very easy run a stock Baja can easily make this event.
See Ya in the dirt!
Posted: Fri Jan 30, 2015 01:27 PM
Hey Off-Roaders!!
Hassampa River Run .... is Canceled!!!
Due to: " there be water in that wash. "
We have not talked about a rain date yet ... So more to come.
azdesertrat87
azdesertrat87
Posted: Fri Jan 30, 2015 08:45 PM
ya I kinda figured but better safe than trying to out drive a 5 foot wall of angry water
Posted: Fri Jan 30, 2015 09:09 PM
Keep us updated. I'd like to go but tomorrow I already had too much going on
No new posts Events and Get Togethers World Wide Hassayampa at I-10 Closed! (Old Playday area) 2 Dirtjunkie 1794 Hassayampa at I-10 Cl...
 Fri Oct 27, 2017 02:13 PM
No new posts Events and Get Togethers World Wide Hassayampa Pics/Vids 5 wideopenmotorsports 4128 Hassayampa Pics/Vids
 Sun Nov 22, 2015 10:34 PM
No new posts Events and Get Togethers World Wide 2015 Hassayampa Play Day Official Thread
60 wideopenmotorsports 30468 2015 Hassayampa Play D...
 Mon Nov 09, 2015 11:22 PM
42 wideopenmotorsports 14349 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 03:14 AM
No new posts Events and Get Togethers World Wide 2015 Hassayampa T-Shirt 2 wideopenmotorsports 2924 2015 Hassayampa T-Shir...
 Fri Jul 17, 2015 02:43 PM
