Latest: rcwtony
Overall: 3607
Visitors: 149
Total: 149
20: Event Calendar
55: Home
67: Event Calendar
93: Contact Admin
100: Event Calendar
109: Contact Admin
120: Event Calendar
147: Garage
1450Bug Build
1450bug
1450bug
Posted: Thu Jan 22, 2015 05:24 PM
Spoke with AZTRANSAXLE today. Sounds like a 002 is exactly what I need. They are going to build one for me this summer after they slow down from dune season.
Thanks Dalton
Posted: Fri Jan 23, 2015 02:41 AM
did you tell Bill I told you to call him...???
I don't think it get me a discount ... but I like to let him know I sent him some Biss....
Call Bill back... ask him if he has an .002 for a mock-up so you can get started.... they are a lot lighter with all the gears out of them... ask Bill how much longer an .091 is than .002 and make a spacer for the nose cone so when you need to upgrade to an .091 the conversion will be a snap! just use longer nose cone studs on the .002 Bill will have them..
if Bill does not have an .002 Mock-up in stock because someone else is using it ... Just buy an .002 core trans from him and bring it back to him when he is ready to build your trans.... I recommend using a stock gear stack if you are going to drive it on the road. it works well with 31" or 33" tall tires... maybe a lower 1st gear. have Bill do all the goodies but you wont need aftermarket gears. use stock gears unless you want to go lower on 1st you may need to.
your car looks a little heavy for a 1776... go at least with a 1915 or highter ... keep the compression low... I like 8.1 - 8.5ish for pump gas.
if you go turbo don't go highter than 7.5 .. I love turbos... Turbos are not very good for a daily driver ... unless you are very careful about how you set it up...
Turbo MTR run HOT!! and this shortens the life of the MTR. the Oil gets too thin...
103 SuburbanLegend 159387 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
26 1963BAJA 11854 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 15712 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 6654 New Class 11 Build - P...
No new posts VW Volkswagen & Baja Bug General Discussion Beginner Baja build help? 3 prorcguy 3768 Beginner Baja build he...
 Thu Oct 16, 2014 04:32 PM
