Latest: Smokey4
Overall: 3593
Visitors: 103
Total: 103
29: Pictures
42: Home
80: Pictures
86: Event Calendar
100: Home
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Heater issues?
Heater issues?
kinglooie
kinglooie
Post Post subject: Heater issues?
Posted: Fri Dec 15, 2006 05:07 AM
is it possible to to have a heater that works well on a baja bug?? It is my understanding once the rear hood is replaced the chances of heater failure is high......I beleive the term the indivual used was pack a quilt and a ice scraper for th inside of the window?!
Post Post subject: Re: Heater issues?
Posted: Fri Dec 15, 2006 05:16 AM
If you have functioning heater boxes, I don't see what the problem would be.
kinglooie
kinglooie
Posted: Fri Dec 15, 2006 05:26 AM
a close freind of mine was a baja owner when he was young. He tried to explain the way the bug heaters work, I got a little confused, the heat is pulled off the exuast manifold? and forced to the heater junctions(def,floor). He recalled when one put the headers the exaust rerouted and it was a cool winter for the mountain folk who own the Baj version. He also remembered sometimes his fuel lines would freeze, due to the lack of rear deck to keep the heat in? Please correct me , if I'm wrong.
Posted: Fri Dec 15, 2006 05:30 AM
I wouldn't know about that. I don't run a heater (AZ=hellish heat most of the year).
Posted: Fri Dec 15, 2006 06:07 AM
You can have a functioning heater in a baja, you just need the right header that allows you to use the original heater boxes. I had a 65 that I ran a flex tube from one side to the other on the heater boxes (this way I only had to run 1 blower motor), and then ran an electric fan inside the car so I didnt have to run the hoses off of the fan shroud. The electric fan gives you better contol of the air flow, where as the stock way relies on engine RPM.
Posted: Fri Dec 15, 2006 08:44 AM
my baja had heater boxes on it till I relocated it to AZ from Or. The only problem I new of with the baja in the winter was snow pack around the dual carbs from the big tires.
No new posts New Members Air filter issues
Can't keep the Dust out
11 DerekT 5058 Re: Air filter issues
 Mon Oct 03, 2016 01:59 PM
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 5073 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
Really bad issues
4 Pointvirus 2611 Clutch Issues
 Mon Dec 03, 2012 07:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion Ball joint issues
Trying to remove the ball joints from the torsion arms.
13 ChuckD 5325 Ball joint issues
 Wed May 12, 2010 08:06 AM
Baja_Blue View latest post
No new posts VW Volkswagen & Baja Bug General Discussion heater tubes 2 cyberjaw4 1494 heater tubes
 Mon Feb 16, 2009 10:13 AM
cyberjaw4 View latest post
