Latest: ecthemc
Overall: 3567
Visitors: 238
Total: 238
02: Home
09: Pictures
21: Pictures
83: Home
84: Home
87: Pictures
113: Home
127: Home
156: Event Calendar
158: Pictures
168: Baja Forums
171: Baja Forums
176: Links
182: Event Calendar
185: Baja Forums
187: Baja Forums
190: AMAZON.com
191: Baja Forums
192: Baja Forums
193: Baja Forums
194: Baja Forums
195: Baja Forums
197: Event Calendar
198: AMAZON.com
202: Home
204: Baja Forums
205: AMAZON.com
207: Baja Forums
208: Baja Forums
209: AMAZON.com
210: AMAZON.com
212: My Account
213: AMAZON.com
214: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Baja Forums
221: AMAZON.com
223: Pictures
224: Baja Forums
225: AMAZON.com
226: Baja Forums
227: AMAZON.com
229: AMAZON.com
230: Baja Forums
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: Event Calendar
235: Baja Forums
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- oil light
oil light
terribletommy
terribletommy
Post Post subject: oil light
Posted: Wed May 21, 2014 04:49 AM
Hey guys. So I put a stereo in my baja bug and now the oil light wont turn off unless I turn off the stereo! Its driving me crazy. Why is the power draw from a basic cd player effin up my cluster? Any ideas? I ran constant off far right, and obviously ignition from ignition on far left. (Looking under dash)
The four b\'s.. beer, babes, buddies, and baja bugs... oh wait thats five.
Posted: Thu May 22, 2014 01:04 AM
well the oil light is negative and the cluster is positive charged. sounds like you are grounding the oil light wire somewhere.
terribletommy
terribletommy
Posted: Thu May 22, 2014 01:27 AM
Im confused because I didnt unplug anything. I went over the wires for the oil light. If I turn off the radio everything works as it should. Im stumped. Do you think maybe the radio isnt grounded well enough and its trying to compensate by drawing a lot of juice and falsely grounding the light? Like maybe the weak power from a large draw is tricking it into thinking its being grounded by the sensor? Because im pretty sure the sensor is the negative since thats how you check if the light works, by grounding the plug on something. I really hate driving it with the dang light on, but a guy needs his tunes!
Posted: Thu May 22, 2014 01:33 AM
try unplugging the oil light from the motor side... maybe there will be some insight there.
terribletommy
terribletommy
Posted: Thu May 22, 2014 05:02 AM
Posted: Thu May 22, 2014 08:56 PM
Maybe its the speaker wires are bleeding over to the oil light. this cant be that completed ... you are over looking something simple.
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 83794 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
what do you use
4 bdrdunes 2106 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2405 Re: Brake light switch...
 Sun Nov 17, 2013 07:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 10854 best way to mount a li...
 Mon Feb 07, 2011 02:31 AM
woodin View latest post
No new posts Projects and Builds Finally Mounted The Light Bar 2 Hamm0ckjames 2371 Finally Mounted The Li...
 Tue Aug 24, 2010 12:20 AM
az350x View latest post
