Latest: jor_dang420
Overall: 3597
Visitors: 87
Total: 87
15: Event Calendar
26: Event Calendar
31: Links
42: Event Calendar
43: Home
66: Drivers
68: Event Calendar
75: Event Calendar
81: Pictures
82: Event Calendar
86: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Starting a1970 baja build
Post Post subject: Re: Starting a1970 baja build
Posted: Tue Jan 21, 2014 09:26 PM
MRBilly wrote:
Dalton-
Nicely done trunk retention! I would've loved to have done that on mine but I am not so good a welder
I have seen the "trunk retention" done in wood... Shocked
OldGoat
OldGoat
Post Post subject: Starting a1970 baja build
Posted: Fri Jan 24, 2014 11:31 PM
I, too, am building a 1970 baja. I have cut out and replaced the floors. I'll be cleaning, priming, doing the rust encapsulation, sound and temp proofing, and rhino liner or similar on the bottom and fender wells, after a little more cancer surjery on the beast. I need a little advise from a knowledgable and experienced builder. I am putting a 240 hp Subaru H6 SVX mill behind a bus tranny that I havenn't got yet. My question concerns the differences between the 091 and the 094. Will the 094 fit the bug, and what are the pro and con associated with each. I'm going with bus tranny for strength, and plan to put the super diff and a bell housing change rather than an adapter, to take advantage of the heavy duty Sub clutches available. I welcome any and all help.
SubDub
Posted: Sat Jan 25, 2014 01:45 AM
What here's what I think I know....
The 091 bus transmission shifts from the nosecone and if you're going to have a back seat this is the easiest one to adapt.. The weak link on the 091 is the reverse gear.
Now the 094 bus transmission is the side shift it has a real reverse gear.. But is challenging to get the shift linkage to work properly. The 094 bus transmission is about half the cost of an 091 bus transmission because of the shifter... With the 091 bus transmission becoming rarer... The performance manufacturers are starting to produce performance gears and other performance parts for this transmission.. If I'd get need the rear firewall and the rear seat in my Baja I wouldn't use the 094 bus transmission.. That I am building a street Baja not a trail pounder..
You may be wasting your money of purchasing a super dif.. I use a type four
diff that seems to be plenty strong
Posted: Sat Jan 25, 2014 01:48 AM
You can either go with the kit to get the shifter to work on a 094 or use a cable shifter.
Posted: Sat Jan 25, 2014 01:51 AM
094 with a kit on it...
phoenix.craigslist.org...13414.html
Posted: Sat Jan 25, 2014 01:52 AM
phoenix.craigslist.org...71554.html
Posted: Sat Jan 25, 2014 01:59 AM
I have not used Don's for any work. I use Bill at 602-269-1444 I have always been very happy with his work.
I am not recommending Don's bus box... [b] I would check up on any vender before I spend any money with them.
look on www.thesumba.com for some reviews.
Posted: Sat Jan 25, 2014 03:18 AM
if you can find it.... the 094 comes in a 5 speed stock....
Posted: Sat Jan 25, 2014 03:20 AM
sorry... its www.thesamba.com
5 Admin_AzBaja 8117 Baja Bugs on Wiki need...
1569 mufasavnvmc 1048350 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 252778 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1052 FREE VW BAJA'S
0 Northmountainauto 2079 Shop Baja
