Latest: bawward
Overall: 3614
Visitors: 109
Total: 109
39: Pictures
41: Garage
69: Garage
102: Event Calendar
small project
1 2 3 4
azdesertrat87
azdesertrat87
Posted: Tue Oct 01, 2013 02:53 AM
don't froget the little o-ring in flywheel Also you'll need to check flywheel end play, just try to pull the flywheel in and out of the engine, you should only be able to feel only the slightest end play. Any more and there are issues in the block, and finally clean the threads in the crank and gland nut with brake clean and apply red lock tight to the gland nuts threads and 250 ft-lbs or else you'll take out the crank/flywheel from the dowl pins shifting and moving about oh ya don't froget to lube the the seal and crank where they touch each other and a little oil on the three shims would'nt hurt either
gman3850
Colonel
Colonel
gman3850
Posted: Tue Oct 01, 2013 05:02 AM
rear main, flywhell o ring and fly wheel re surface is getting done at dugs bnb, Also getting gland nut and bearing replaced as wheel as the input shaft seal replace. Also getting some new gear oil and a clutch pressure plate and throw out bearing.
entire drive train in the back of my car
some headliner
azdesertrat87
azdesertrat87
Posted: Tue Oct 01, 2013 05:06 AM
cool hope to see you at the Hassayaempa Tony sounds like he's brewing up some really fun things for this years run and if I can keep my torsion bars in one piece I want to do a few of the activities!
Posted: Tue Oct 01, 2013 03:21 PM
Cool!
Staff Officers
Posted: Tue Oct 01, 2013 06:56 PM
It was a blast last year and I did not have a baja...
Post Post subject: Re: small project
Posted: Thu Oct 03, 2013 07:23 PM
So you have a rear engine SUV???? Shifting must be a PITA. Cool
gman3850 wrote:
some headliner
That headliner may have a few puckers, but I like it. This is how I have envisioned VW headliners should be ever since the 1960s. And you aren't out to win 1st place trophies at car shows, are you? Tell us a little bit more about how you installed it and what material(s) you used.
gman3850
Colonel
Colonel
gman3850
Posted: Fri Oct 04, 2013 07:00 AM
its just 60" of 1" cotton babbing and 63" for grab frabric so i could wrap the edges and trim. Used spray adhesive and started upfront and worked twords back of the car to stick to roof, then used a puddy knife to push edges into channels
Posted: Fri Oct 04, 2013 02:41 PM
Looks similar to the one I did a couple months back. Excellent job.
Turn bare metal into a nice neat and simple headliner.
gman3850
Colonel
Colonel
gman3850
Posted: Fri Oct 04, 2013 05:30 PM
yep exactly, iread your thread and found it, was sad they didnt have any reed so it isnt as stiff as i wanted it and now has some folds, but hey it works and does the job
ButchW
ButchW
Posted: Mon Oct 07, 2013 12:57 PM
Great idea for headliner. I've put the stock headliners in before and they're fine.. but you have more options with this.. Very cool!
gman3850
Colonel
Colonel
gman3850
Posted: Mon Oct 07, 2013 05:24 PM
[quote="MojaveRacer208"]
didnt even notice this comment haha no its a mazda 3 hatchback
Posted: Thu Oct 10, 2013 09:06 PM
Cool
Laughing Laughing Laughing
I really didn't know if it was a Kia or a Rav4 or a Matrix or a whatever. But I DO think Mazda would be kinda surprised...
1 2 3 4
1199 Dalton 458635 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 5802 Project Purple People ...
88 Dirtjunkie 78850 Project II
65 PaDan 68824 Re: My project
 Thu Feb 11, 2016 07:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 10695 Re: new project
