Visitors: 119
Total: 119
01: Pictures
33: Pictures
47: Pictures
61: Home
64: Home
66: Home
87: Event Calendar
97: Home
112: Event Calendar
small project
1 2 3 4
Posted: Fri Sep 27, 2013 04:44 AM
It's normal for it to want to roll while running and in neutral.
Post Post subject: Re: small project
Posted: Fri Sep 27, 2013 02:17 PM
gman3850 wrote:
i couldnt feel really any play in the pulley, only thing now is the 1,2 side likes to make a popping sound at idle, so my guess is it needs to be flashed timed instead of static timed. As for the clutch i adjusted the wing nut some tonight and that seams to work for the intial take off but unless i disengage the clutch by taking it out of gear it seems like it want to hold and keep moving
check to see if you have a good "boden bend" if you don't have a good one it will not disengage the clutch.. I would just replace it.
Posted: Fri Sep 27, 2013 03:05 PM
Couldn't find what a boden bend was in google. lol
I misread, maybe the previous owner used the wrong throw-out bearing/pressure plate combo?
Posted: Fri Sep 27, 2013 07:31 PM
It is the Yellow tube on the driver side of the transaxle in the photo. it should bow down or bend down etc. like in the photo.
Or some one could of put a mis match presure plate into the car. If your baring rides on a tube bolted to the inside of the bell houseing. it should be just fingers on the presure plate and the bearing will have an inverted cone for the fingers ti ride in.
Early presure plate will have a flat ring on the presure plate plus the bearing will have a matching flat face. The baring will ride in the forks and be held into place by to hair pin type clips.
gman3850
Colonel
Colonel
gman3850
Posted: Sat Sep 28, 2013 09:07 PM
well after last nights nasty sounding driving i got up this morning and decided to attack the bowden tube. Got a close look and there was only 2 small washers on there, well i found a spacer that would have worked perfect gave the right amount of bend but the cable was about a 1/4 inch to short, so i settled for another spacer that was about 1/4 in smaller than the first and was able to get the wing nut over the cable. Well shifting into 1st is so much nicer reverse is still sketchy, would have liked that first spacer to work. But for right now it sounds 1000k better
gman3850
Colonel
Colonel
gman3850
Posted: Sat Sep 28, 2013 10:49 PM
well that was short lived, shifted great for the first two miles than i couldnt shift at all had to shut car off to get to first, pulled engine and inside
the bell housing i covered in oil
gman3850
Colonel
Colonel
gman3850
Posted: Sun Sep 29, 2013 06:24 PM
well figured out why she wont shift
Posted: Sun Sep 29, 2013 07:01 PM
That will do it....!
gman3850
Colonel
Colonel
gman3850
Posted: Sun Sep 29, 2013 07:04 PM
now just got to find out if the rear seal is leaking, already know i need to do the trans one
gman3850
Colonel
Colonel
gman3850
Posted: Sun Sep 29, 2013 11:31 PM
shes leaked just a little oil over the years
Posted: Mon Sep 30, 2013 12:37 AM
WOW, looks like mine did once. LOL
gman3850
Colonel
Colonel
gman3850
Posted: Mon Sep 30, 2013 12:39 AM
did u rebuild or re seal yours
Posted: Mon Sep 30, 2013 12:42 AM
Mine was mostly due to the swing axle boots, so I replaced them a couple of times before I figured out they were getting pinched causing them to leak. Now the leaking is minimal. I just saw your Flywheel Holy Crap!
Posted: Mon Sep 30, 2013 02:35 AM
All things considered I'm not sure that you are staring down to rebuild yet.. You just got the car. Go out and have some fun in it.. Check your oil pressure make sure it has oil in it and drive it for a while.. Replacing that rear main seal is kind of a tricky... There's some voodoo and some tricks to replacing it correctly if you don't it will still leak.. Someone else on this website that's better at it than me that will explain how it's done..
On the transmission: I would just take it down to Arizona transaxle exchange talked to Bill tell them I sent you and you would like to have your transmission vatted and cleaned. I'm sure you will be please on how little it costs...
Stock flywheels and pressure plates are cheap just buy a new ones.. By the time you get done resurfacing what you have will outweigh the cost of just replacing them..
Why you have the transmission out set it Bell housing down with no weight on the input shaft use some wood,,, check to see if the transmissions rear main seal leaks,,, this would be a good time to replace it... Matter of fact it be a good time to replace the transmission oil you probably don't need the synthetic stuff just some regular old oil... Have build check your input shaft bushing he could replace it very easily this will improve your shifting. By slightly pressurizing the transmission you can check to see if any seals are leaking will never know what you'll find under the gunk...
Posted: Mon Sep 30, 2013 10:18 AM
Dirty, My swing boots would bind over the Trany Horns too. Had to replace them every few months. Sucked.
1 2 3 4
1199 Dalton 339098 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3377 Project Purple People ...
88 Dirtjunkie 62678 Project II
65 PaDan 57021 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8327 Re: new project
