Latest: slyster
Overall: 3568
Visitors: 255
Total: 255
28: Pictures
42: Event Calendar
49: Pictures
67: Event Calendar
70: Home
84: Event Calendar
119: Pictures
138: Home
154: Baja Forums
164: Baja Forums
166: Baja Forums
168: Baja Forums
170: Baja Forums
173: Baja Forums
176: Baja Forums
178: Baja Forums
188: Baja Forums
189: Baja Forums
190: AMAZON.com
195: Baja Forums
197: Pictures
198: AMAZON.com
202: Baja Forums
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: Baja Forums
209: AMAZON.com
210: Baja Forums
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
215: Baja Forums
216: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Event Calendar
221: AMAZON.com
223: Baja Forums
224: Baja Forums
225: AMAZON.com
226: Baja Forums
227: AMAZON.com
229: Baja Forums
230: AMAZON.com
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: Baja Forums
241: Baja Forums
242: AMAZON.com
243: Baja Forums
244: Baja Forums
245: AMAZON.com
246: AMAZON.com
247: Baja Forums
248: Baja Forums
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: Baja Forums
254: Baja Forums
255: Baja Forums
small project
1 2 3 4
Posted: Tue Sep 24, 2013 04:04 AM
Sounded pretty good!
Those push rod tubes are pretty easy to pull out and put new seals on if they are the reusable kind.
gman3850
Colonel
Colonel
gman3850
Posted: Tue Sep 24, 2013 04:08 AM
well i figure if i am going to pop heads off might as well do new pistons, jugs, rings, all push rod tubes and seas, that way i dont have to go back in. but for right now just gonna keep it so it doesn't leak on my driveway
Posted: Tue Sep 24, 2013 04:16 AM
maybe it just me..... but it has been my experience,,,, that all VW air cooled motors leak oil. I have never own one that did not leak...
Now that being said I have been able to fix non-running leaks. but when the motor is running it seem they leak/sweat oil...
Post Post subject: Re: small project
Posted: Tue Sep 24, 2013 05:22 AM
EVERY Race engine I have had built is leaking oil by the end of the race.
If you drive an air cooled VW just plan on a leak here and there.
gman3850
Colonel
Colonel
gman3850
Posted: Tue Sep 24, 2013 05:26 AM
Well what I really want is a turbo'd 2.3 mustang motor back there
Posted: Tue Sep 24, 2013 05:37 AM
Buy and ecotec 2.2 and call it a day. It will work great and give you close to 200hp when set up correctly
gman3850
Colonel
Colonel
gman3850
Posted: Tue Sep 24, 2013 05:39 AM
Ya at double or triple the cost after everything is said and done haha
Posted: Tue Sep 24, 2013 08:58 PM
The Ecotec engine itself is not expensive. What IS expensive is 1st the adapter and clutch, which will set you back another 2/3 the cost of the car that would run. Then 2nd, the REAL expensive part is the electronics which can often cost a couple thou. Then there is the motor mounts, throttle cable, (and you have to have either the throttle pedal and wiring for the later fly-by-wire throttle body or the earlier cable throttle body. Then add in the cost of the headers and the custom exhaust and muffler, a custom air cleaner setup, High pressure FI fuel pump and lines, etc................
And while they DO make good power, the horsepower claims just keep climbing and climbing. Kinda like "how big was the fish that got away?"
Remember too, that more hp at the flywheel means more expensive gear box and the rest of the drivetrain.
I'm not real fond of turbo engines for a desert and mountain offroad car. They are great for quick blasts on sand dunes and if that is all you do offroad, then a turbo is good. But for general purpose use they are not a good thing. So what engine and induction system you choose depends heavily on how you plan to use the Baja.
For info on a 2.3 Ford swap, talk to AZBaja. He's run a 2.3 Ford for many moons.
Last edited by MojaveRacer208 on Tue Sep 24, 2013 08:58 PM; edited 1 times in total
gman3850
Colonel
Colonel
gman3850
Posted: Tue Sep 24, 2013 09:03 PM
Ya for the moment ill stick with the vw for my budget.
Took bug around the block today. Now the problem is when I have clutch pedal pushed to the floor the vehicle still wants to go. What can I do to fix this.
Posted: Tue Sep 24, 2013 10:59 PM
check this out... this is a deal!
phoenix.craigslist.org...14786.html
Make him an offer
gman3850
Colonel
Colonel
gman3850
Posted: Tue Sep 24, 2013 11:01 PM
Ya my budget is like if you take a zero off that haha.
Posted: Tue Sep 24, 2013 11:34 PM
Ok do what I do..... carry cheep oil with you at all times.
gman3850
Colonel
Colonel
gman3850
Posted: Wed Sep 25, 2013 12:09 AM
ya thats what i was planning haha
azdesertrat87
azdesertrat87
Posted: Fri Sep 27, 2013 03:45 AM
there are a lot of things that could cause the car to want to roll with the clutch pedal depressed. The first thing I would check is the clutch pedal free play not more than 3/4" I hate to do this to ya but I would really recommend pulling the pedal assembly to inspect the clutch pedal linkage. it's a hook style and are usually about worn out so your first offroad venture and it Will break so you have to double clutch it to get home! Another thing, grab the pulley and see if there is any front to back movment usually if there is its from the thrust bearing ie complete rebuild, for referance stock end play is around .004-.008". the thrust bearing takes an especally hard beating off road when you "pop" the clutch and that slap is transferred to the thrust bearing. Good luck
gman3850
Colonel
Colonel
gman3850
Posted: Fri Sep 27, 2013 04:20 AM
i couldnt feel really any play in the pulley, only thing now is the 1,2 side likes to make a popping sound at idle, so my guess is it needs to be flashed timed instead of static timed. As for the clutch i adjusted the wing nut some tonight and that seams to work for the intial take off but unless i disengage the clutch by taking it out of gear it seems like it want to hold and keep moving
1 2 3 4
1170 Dalton 253478 My 69 project
 Wed Dec 06, 2017 01:38 AM
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1160 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 48382 Project II
65 PaDan 46575 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6390 Re: new project
