Visitors: 336
Total: 336
03: Event Calendar
27: Pictures
29: Event Calendar
93: My Account
103: Home
104: Event Calendar
118: Pictures
147: Event Calendar
149: Event Calendar
157: My Account
162: Event Calendar
170: Baja Forums
171: Baja Forums
172: Baja Forums
173: Event Calendar
177: Baja Forums
178: Event Calendar
179: Baja Forums
182: Baja Forums
183: Baja Forums
184: Baja Forums
191: Baja Forums
192: Baja Forums
193: Baja Forums
194: Baja Forums
196: Baja Forums
197: Pictures
198: Baja Forums
199: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: Baja Forums
206: Baja Forums
207: Baja Forums
208: Baja Forums
209: Baja Forums
210: Baja Forums
211: Baja Forums
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Event Calendar
221: AMAZON.com
222: Event Calendar
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: Pictures
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: Baja Forums
234: AMAZON.com
235: Pictures
236: Pictures
237: Pictures
238: Baja Forums
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: Baja Forums
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: Baja Forums
254: Baja Forums
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: Baja Forums
259: Event Calendar
260: Baja Forums
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: Baja Forums
266: Baja Forums
267: AMAZON.com
268: Baja Forums
269: Baja Forums
270: Baja Forums
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: AMAZON.com
278: AMAZON.com
279: AMAZON.com
280: Pictures
281: AMAZON.com
282: AMAZON.com
283: Baja Forums
284: Baja Forums
285: AMAZON.com
286: AMAZON.com
287: Baja Forums
288: AMAZON.com
289: AMAZON.com
290: AMAZON.com
291: AMAZON.com
292: AMAZON.com
293: AMAZON.com
294: AMAZON.com
295: AMAZON.com
296: Baja Forums
297: AMAZON.com
298: AMAZON.com
299: Baja Forums
300: My Account
301: AMAZON.com
302: Baja Forums
303: Baja Forums
304: Baja Forums
305: Baja Forums
306: AMAZON.com
307: AMAZON.com
308: Baja Forums
309: AMAZON.com
310: Baja Forums
311: AMAZON.com
312: AMAZON.com
313: Home
314: AMAZON.com
315: Baja Forums
316: AMAZON.com
317: AMAZON.com
318: AMAZON.com
319: AMAZON.com
320: AMAZON.com
321: AMAZON.com
322: AMAZON.com
323: AMAZON.com
324: AMAZON.com
325: AMAZON.com
326: Baja Forums
327: Baja Forums
328: Baja Forums
329: Baja Forums
330: Baja Forums
331: Baja Forums
332: Baja Forums
333: AMAZON.com
334: Pictures
335: Baja Forums
336: Baja Forums
My 69 project
1 2 3 ... 18 19 20 ... 78 79 80
Posted: Sat Aug 31, 2013 12:24 AM
Will that took a lot longer than I expected. I could only work in the back of the car for as long as my back in knees would hold out... I took each wire cut it to size, soldered it,and shrink wrapped it.. The only wires that I didn't cut were the ones that were encased in shielding by cutting that wire I would change the resistance of the wire and would confuse the computer.. And to go back in and remove my remote oil filter and go back to a stock oil filter. The pressure at start up was too great and would blow my seals.. The fuel system that I set up as the worst vapor lock problem I've ever encountered... I plan on taking this weekend and redesigning my fuel delivery system to try to correct this problem.. At least now with the amplifier hooked up in the back I will be able to get some decent tunes back into the shop.. My project almost done.. I keep fighting the urge to strap down my makeshift radiator and take it for a spin.. Who knows I just might..
Posted: Sat Aug 31, 2013 12:33 AM
I'm dying to check out my new power steering set up, it really works good in the garage.. I have not decided on running a fourth condenser underneath the radiator yet,... If it gets a little cooler this weekend on a pull the rail out and replace the tie rod ends and then I'm probably going to take a day run up to Crown King.
Got a call from the radiator shop. My replacement radiator is on its way and should be here next week.. If I can solve the vapor lock issue then that'll be the last piece that I will need to complete the car enough so that I can drive it on the road.. I keep toying with the idea of reworking the rear bumper little bit more I'm really not happy with the way that it came out so I'm probably going to change it I'm in a need to do that before I start on the radiator..
1engineer
1engineer
Posted: Sat Aug 31, 2013 05:43 AM
Dalton, great work. Probably not want to go Saturday as the AZ Virtual Jeep Club is running the back road to Crown King, and last I looked there was apprx 160 Jeeps registered to make the run. Might be fun to watch them trying the difficult spots showing off though. There is a Rally Fighter registered to go up, might be able to call it a "Baja" as it is more than capable and has VW tail lights from factory.
will have to create one later
Posted: Fri Sep 06, 2013 03:23 AM
Well the fuel systems done I just need to put it back together again..
Posted: Fri Sep 06, 2013 03:24 AM
The heater cores done I just need to put it back together...
Posted: Fri Sep 06, 2013 03:27 AM
Others places out there that want over 150 bucks for the coolant overflow....
I think I have about eight bucks and some change invested in my coolant overflow...
I think I'll keep the logo it's a nice touch,,
Posted: Fri Sep 06, 2013 03:30 AM
Guess what showed up today?????
this one is done exactly to the blueprints that we both signed off on,,,
SWEET!!!!!
Posted: Fri Sep 06, 2013 03:31 AM
I can see the finish line.
Posted: Fri Sep 06, 2013 04:49 AM
Congrats!
Posted: Fri Sep 06, 2013 04:50 AM
Congrats!
vwboat
vwboat
Posted: Fri Sep 06, 2013 03:48 PM
Lots of hard work and planning paying off. Looking good.
VWBOAT(john)
Posted: Fri Sep 06, 2013 08:09 PM
Dalton,
It is looking really good. Can't wait to see it out of the garage in the sunshine.
Posted: Sun Sep 08, 2013 07:11 PM
Well it was the first day in months that I can have the garage door open without melting.. I decided it would be a good day to clean out the garage.
But to do that I had to move my car out..
youtu.be/kDODyDD3xuk
Enjoy....
Posted: Sun Sep 08, 2013 07:21 PM
Cool! Kinda forgot to clean out from under it first? LOL
Posted: Mon Sep 09, 2013 12:38 AM
Yeah was excited to take it for drive and forgot to check underneath and remove the blocks from underneath the tires,,, while I was trying to make sure that I had everything covered so I could clean the garage floor and guess what I forgot to do....???
I forgot to rebuild the power steering pump!!... I do the same thing that the high-performance shop do... I port the pump put a heavier spring in and sometimes change the valve... I'm going to see if I can find my old notes on what I did to the last pump, but I remember I had the same issue.. I'm pretty certain all is I need to do is ported out and change out the spring won't know until I get into it.. This will save me about 300 bucks!
This week I am going to start mounting the radiator.. But before I can do that I need to rework the rear bumper.. This should be quick I'm only going to move two supports..
I've got a readjusts the shifter in the clutch I can't seem to find third and fourth gear.. And the clutch needs a bit of adjusting...
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3408 Project Purple People ...
88 Dirtjunkie 62763 Project II
65 PaDan 57092 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8348 Re: new project
38 NoKnowledgeCollegKid 21785 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
