Visitors: 134
Total: 134
30: Home
37: Event Calendar
47: Pictures
76: Event Calendar
82: Event Calendar
104: Event Calendar
112: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Doing good things for a Marine
1 2 3 4
The following users give thanks for this topic ironcoffin - Thu Aug 01, 2013 05:15 PM
Post Post subject: Doing good things for a Marine
Posted: Sat Aug 17, 2013 05:32 PM
I'm meeting Matt there at 10:30 today to see what we can get accomplished. Smile
Yummi
Yummi
Posted: Sat Aug 17, 2013 05:39 PM
^^^^ Sweet!
Posted: Sat Aug 17, 2013 09:28 PM
Thanks Matt and Perri!
That engine is going to need some help. Crappy rebuild. It appears to have a standard sized bearings though. The Case had one of the Studs unscrew with the nut and another had been cross threaded when the nut was put on. Too bad it wasn't the one that backed out! LOL
I'll let one of them elaborate as I really don't know enough to sound intelligent. Lots of silicone in places I don't think it should have been , around bearings, etc. the lifters also appear to have been sanded with a belt sander. I guess one of the Oil rings was also installed wrong..?
Yummi
Yummi
Posted: Sat Aug 17, 2013 11:51 PM
Well, the tear down is complete. Not as good as I had hoped for.
Quote::
Tobiism:
well the tear down didnt go too well on the engine. Case needs work- 1 main case stud pulled out of the engine because the wrong fasteners were used and it galled up the threads. One main case stud completely stripped out. The case was not decked for the 94mm cylinders. The case was so sloppily covered in RTV there was no doubt it would have gotten into the oil pump. It had the wrong oil screen in the sump that would have led to oil starvation. The lifters looked like they were faced on a belt sander, the cam bearings are shot and look like old reused units. The rods did not look rebuilt but will probably(still need to be inspected) be okay, the crank and bearings looked serviceable. With the step in the heads and from how far down the pistons were in the cylinders it looked to be around .185 in deck height along with semi hemi heads! Probably had 6:1 compression. All in all one of the worst rebuilt engines Ive seen. However, if Kenny finds the case to be serviceable it shouldnt take too much in parts and labor to put it back together.
Quote::
Conundrum:
Thanks guys for the hard work on what is arguably on of the hotter days here in Phoenix. On the bright side we are almost on a downhill side.
Yummi
Yummi
Posted: Sun Aug 18, 2013 03:32 AM
Quote::
Tobiism:
No big deal! It wasnt that hot in there.
Here are some pics-
Talk about deck height! Case not decked for the 94 cylinders
RTV everywhere!
welded semi heads
old crappy worn lifters they attempted to resurface on a belt sander
Posted: Mon Aug 19, 2013 02:45 PM
Here's a couple of pictures I was able to snap...
Posted: Tue Aug 20, 2013 06:24 AM
Make sure you get me the 468x90 baner for any co. the donates to the project. I can added them to the rotating links on top of the page.
Yummi
Yummi
Posted: Wed Aug 21, 2013 01:37 AM
Well quick update:
This sucks balls. Got word from the machine shop. New block is needed. Dang, there goes more wind from my sales.
BRB with a good update.
Yummi
Yummi
Posted: Wed Aug 21, 2013 01:44 AM
Back to Christmas in August – Santa bring me an engine block!
Santa did manage to bring this:
Some very nice HID lights. Will light up the ninght sky like nobodies business. As always “hoodlum” aka “Project Manager” is keeping a watchful eye over the good stuff.
Posted: Wed Aug 21, 2013 02:08 AM
Sorry to hear that, but really I'm not surprised... Sad
ironcoffin
ironcoffin
Post Post subject: Re: Doing good things for a Marine
Posted: Thu Aug 22, 2013 08:10 PM
I know they're have been a couple of hick ups getting this project off the ground, but I wanted to take the time to thank everyone again. Everyone involved with this build from information to donations has been extremely helpful and resourceful. I can't wait to see my brothers face when he gets to enjoy everyones hard work that is going into this project. So, once again thank you and God Speed!!!!
https://www.giveforward.com/fundraiser/fcs2/doing-something-good-for-a-marine-oorah-
Yummi
Yummi
Posted: Sun Sep 01, 2013 10:45 PM
Well, this project got stalled a bit. I had a work project that had to take priority. Back on it. Game plan, buy block, get this bad boy rolling and going under its own power. Thanks for all the support. Just did not want anybody to think this had fallen from the radar, or been stymied.
Will get better on updates as we get back in gear.
Thanks again.
Yummi
Yummi
Posted: Tue Sep 24, 2013 02:26 PM
Well, sorry for the delay. Boy has my personal been on a tear. Some exciting changes are coming my way in the near future and it takes boat loads of time to address them. Big moves a foot.
Still working on this project. The motor set back was huge. And now we have a block, sleeves, etc. Hope to have it fired in the near future. Then we will have a time crunch on this project so all you helpers – get ready to help!
Shout out to Chris G. for some nice led lights. Really nice. Buy em here at okledlightbars.webs.com/
Back on track and will tell more about the personal changes sometime in the near future.
Thanks again Chris!
Posted: Fri Oct 18, 2013 11:57 PM
We are going to need a piston 94 x69 cima mahle. One of them after clean was abused by a hammer to badly to function. Used is fine.
Posted: Wed Oct 30, 2013 01:50 AM
This has been interesting. I stripped the crank, it looked nice til # 3 rod came off. They had "rebuilt" the engine with a damaged crank. The bearing had spun and raised the journal. It would not polish out.
Special thanks to Doug's Bugs and Bunnies for parting with a good German standard crank.
It went together well until I went to install the almost new Chinese oil cooler and adapter. See the picture of the seal. It is odd shaped because the oil holes obliterated the sealing surface. Take note: NEVER glue in oil cooler seals. There was enough black death to seal two engine cases on these gaskets.
I got another adapter sans studs. Should be easy to swap. The Chinese studs twisted before the came loose from the aluminum.
The oil pump was another jewel. It has had enough debris passed through it that I doubt it would of made much pressure.
Next neat thing not it is drilled and tapped for full flow, there was even a remote oil filter attached to it. Good thing they left the plug out of the pump that was supposed to force the oil through the oil filter.
Another plus it had the wrong size oil galley holes. It was an early pump in a late case.
This is what a 2mm diameter bead of RTV squished between the case and cylinder looks like. I try to stretch it so it is more like a 1.5 mm bead is a bit excessive by my standards but that is the smallest size on the nozzle.
Tomorrow morning I'll get some studs and see what surprises the tin brings.
29 AzBaja 31795 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
8 AzBaja 3372 photobucket.com is a n...
 Fri Jul 07, 2017 11:37 PM
No new posts VW Volkswagen & Baja Bug General Discussion made a good score......... 1 vtbaja 1875 Re: made a good score....
 Wed Oct 09, 2013 12:19 AM
No new posts VW Volkswagen & Baja Bug General Discussion Doing good things for a Marine 2 Yummi 2599 Doing good things for ...
 Sun Sep 15, 2013 04:53 AM
No new posts Events and Get Togethers World Wide Odd Things You Find . . . 5 wideopenmotorsports 4065 Odd Things You Find . ...
 Tue May 28, 2013 05:19 PM
